Thanks for posting the particulars of your setup. Sounds like you got it dialed in good for gettin what you want out of it
?? could you explain further please?imeasystreet wrote: I may leave the thumper off for a run or two to see if I can get girl whiskey at 100 proof.
In general my feeling is that sounds fine....However all thumpers are not equal.chappy wrote:i also have a question about the thumper ... would it be ok if it was square or sub marine shaped?
Thats when the heads, hearts &, tails run together and are hard to differentiate.chappy wrote:what do you mean by smearing?
The only purpose of the thumper is to provide a secondary distillation in a single run... Therefore, any potential smearing will still come though but at a higher overall %ABV... And while it may be in more concentrated intervals the smearing will still mix into the spirits unless you detect and remove those jars during the blending process... You don't always keep a contiguous series of jars when blending, you might skip a jar or two that just don't seem right along the way... And when using a thumper these may be the jars where the mystery smearing in the thumper ends up coming out into the collected spirits...imeasystreet wrote:How exactly would a thumper create smearing other than, along with the boiler, being run to fast? If that' the only reason, operation is at fault, not the thumper. I suspect a square or submarine shaped thumper might be highly inefficient in terms of heat distribution and vapor flow.
Small primary boilers make for tough cuts.imeasystreet wrote:How exactly would a thumper create smearing other than, along with the boiler, being run to fast? If that' the only reason, operation is at fault, not the thumper.
Vapor flow is definitely an issue. Square corners can certainly cause fores and heads to become entrained within the vessel and re-mingle.imeasystreet wrote: I suspect a square or submarine shaped thumper might be highly inefficient in terms of heat distribution and vapor flow.
Sorry rad but I am going to disagree with this big style. This is the traditional view of a thumper but it is not one that I follow any more. It all depends on how you wish to use the thumper. There are several folks out there that use a thumper mainly for flavour modification. A thumper is a very versatile tool, on the most basic level you can fill it with water. Or you can fill it with wash, or honey, or molasses or anything else that you lke. Stick a dephlegmator above your thumper and you are into an entirely different system.rad14701 wrote:The only purpose of the thumper is to provide a secondary distillation in a single run.imeasystreet wrote:How exactly would a thumper create smearing other than, along with the boiler, being run to fast? If that' the only reason, operation is at fault, not the thumper. I suspect a square or submarine shaped thumper might be highly inefficient in terms of heat distribution and vapor flow.
Several members have built multiple thumper stills... LWTCS has his humper thumper with inline thumpers and there are a few spin-offs as well as several that he may have borrowed concepts from...Kidnapper2 wrote:In the illustration above, with the double thumper. Wouldn't that be a a triple distillation in one run? And if so, why the hell haven't I figured out how to build a monster reflux with a double thumper?
Or, I guess the real question is. Has anyone built a monster reflux with a double thumper? And if so, what kind of results have you gotten from it?
now that sounds interesting to me... i havent even made a run yet and am far off from this...but introducing flavor at the end of the heads sounds like an awesome idea to get more flavor into the hearts... has any of yall tried it yet?LWTCS wrote:The Baker,,
Can also slow your strip down a bit,,,make some rough cuts during this "strip"
Then charge your outfit with your high wines and charge your thumper with the flavor juice to get more adjunct into your keeper spirits.
Can also just do a flavor charge on the thumper with some pre-cut neutral in the primary.......
yesMarshwalker wrote:has any of yall tried it yet?
Was it worth it bubba?LWTCS wrote:yesMarshwalker wrote:has any of yall tried it yet?
This just isn't accurate - or possibly I should say it is an oversimplification. Thumpers do not "consume heat".imeasystreet wrote: And since the thumper consumes heat you need less cooling water. Thumpers increase still efficiency.
g
