I have a 2" x 10' copper pipe along with some fittings to make a VM Still with a liebig (3/4" over 1/2"). Planning on using my Blichmann pot boiler with a 1/2 barrel keg. My thinking was to build a VM still and use neutral spirts to make martini's and flavored cocktails, but I also like whiskey and think a not so pure strip would be nice. I might end up with both a pot and column still, but could a hybrid suffice?
Some questions running through my head.
Time: Is there much of any time advantage running a 16" pot still vs a 50" VM column still ? (using a 2" pipe on both) say a 10 gal batch 10% abv. (I will enjoy the time chillen and distillen though)
Water: My house uses a constant pressure well system and I don't want to run the well pump on/off for 6-7 hours on a VMs, so I think using a 3/8" snake in a large volume of cold water would be easy on the well and electricity - so the pot still wins in this area. (?)
Propane: Time is money / propane is a money burner. I also dont want to burn up 6 hours of propane on a VM column. Does that sound about right - for 10 gal on a 50" VM column? would it burn less running a pot still?
So would a 36" column on a VM still with the ability to shut off both condensers be an excellent pot still and average colunm still?
