braemar wrote:Hi luke777,
Like you i am in oz only down south.
i have been doing this recipe for a while now and have posted my process earlier this year it is much the same as yours but i do mine in 27 litre batches, i use 6 kg. sugar dissolved all at once in around 12 litres hot tap water then i add the paste and Epsom salts together dissolved in around 1 litre of hot water i then add cold water to a total of 27 litres before adding ascorbic acid or lemon juice (it is better if you don't put the acid in while it's too hot around 26-30 deg. c.) then the yeast on top and not mixed in. The difference between the two is i use 140 grams of tomato paste and 1/3 of a tin of the same yeast in 27 litres, considering your volume is double what i do there is a bit of difference in the quantity of paste and yeast what difference that would make i don't know but it is always said the least nutrients the better.
Regards
Braemar
G'day Braemar and everybody!
Yeah the wash I put down went swimmingly that's for sure. It finished up in 8 days and I stripped it last night. Going to put another identical one down tonight so that in a couple of weeks I should have the right amount of low wines for a 50 litre spirit run. Gotta get ready for Christmas ya know!!!
Having trouble with my keg heater element though which I will hopefully have sorted out by the time this wash is done. (Upgrading to better quality)
This will be the first spirit run I have ever done since leaving the Turbo's behind so I am really keen to see how the end product is.
Got a bit of an itch to make some "real" rum in my new pot 'still with a molasses wash but that is all very new territory to me so I will need to do lots of research before I commit to that one.
Anyway, Hello to ya all and keep on stillin'!!!
