OK, first of all, I'm WAY out of my pay grade and in over my head on this one. But, I am trying to learn more about reflux so that someday I might build a column still. This thread seems to be generating a lot of current, useful info about packing material.
Roddy, you seem to be suggesting that if we all just bow down to Irving (Nobel prizewinner), and pay attention to surface areas, that's all there is to it, no more to think about, no ifs, no buts. I think most folks here would agree that a key element of reflux is the area of contact between surface of liquid and passing vapor, but as you begin to maximize that area, then the key areas shift to other factors, such as reduced vapor passageways, rates at which you can run the still, etc. As Croweater suggests, there are many things in play when trying to maximize efficiency in a reflux column. I don't think anyone here is trying to improve on, or trying to surpass Mr. Langmuir's design ideal, we're just trying to get as close as possible to it.
Roddy suggests:
"once we learn that the molecular exchange takes place solely at the liquid/vapour contact area, we can then, and only then, start to investigate and manage all of the parameters which can spoil the ideal case of a constructed, suitable contact area."
Agreed. Even I, a reflux noob, am prepared to accept that exchange happens at liquid/vapor contact area. So, now, and only now, am I prepared to investigate all the other parameters.
That's why I started following this thread in the first place, because Rad started experimenting with a packing that seemed to have been dismissed over the years. This thread seems to be getting a lot of response on the hows and whys of how various packings work, and how the efficiencies can be improved. It has at least really helped me get a better understanding of how the reflux columns work, and I'm grateful for all the back and forth, guys, thanks!
