How to connect Keg boiler to riser??
cat herder
Post by cat herder »
I see lots of builds that use a keg as a boiler. I've found a design that is simple enough that I can build it: http://homedistiller.org/forum/download ... p?id=12153, but I haven't found any description about how to connect a keg to a riser. My understanding is that I'll need to clamp it somehow. What do others use? Thanks for the pointers.
bearriver
Re: How to connect Keg boiler to riser??
Post by bearriver »
Lots of ways to do it. Here ya go: http://homedistiller.org/forum/viewtopic.php?t=27056
hawgwrench
Post by hawgwrench »
Two inch tri clover flange....eBay's loaded with the things, anywhere 'tween two and five bucks. You'll need some good flux an a stick of silver solder. It takes a spell to get everything cleaned and then hot enough to join, just be patient. Have a shot first....helps with the shakey hands.
Patience....the early bird get's the worm, but the second rat get's the cheese.
FreeMountainHermit
Post by FreeMountainHermit »
cat herder wrote: but I haven't found any description about how to connect a keg to a riser. My understanding is that I'll need to clamp it somehow. What do others use? Thanks for the pointers.
Took about 30 seconds to find the answer.
https://www.google.com/search?gs_ivs=1& ... +keg&tts=0" onclick="window.open(this.href);return false;" rel="nofollow
http://homedistiller.org/forum/viewtopic.php?t=7153
Blah, blah, blah,........
cat herder
Thanks all :)
Yet another reason to do ample research before attempting practical application... :thumbup: The Tri-clamp method has been discussed extensively so it's virtually impossible to overlook if you do enough research into the theories and fundamentals, and peruse the builds of other members... :ewink:
If you want to look at ideas. Click HD Google search. Then click Images.
Scroll down until you see something interesting and click on it.
maheel
Post by maheel »
depending on your keg this idea is free and comes with the keg
it's an A type keg and australian 50mm tube (usa tube is diff ID or OD, but not sure)
Prairiepiss
Post by Prairiepiss »
Take your column and shove it down in there. Now take a BFH and beat it into submission. Making it bend to your will. Now you have a good connection.
rubber duck
Post by rubber duck »
Pretty good idea, does that seal well? Can it pass a mirror test?
Prairiepiss
I will let you tell him how to remove the valve RD. you do such a good job at it.
On my first build I went with this the set up in the following link: It's easy strong but the downside is it is a bit more expensive.
http://www.milehidistilling.com/2-inch- ... o-keg-kit/" onclick="window.open(this.href);return false;" rel="nofollow
My current build on a 4" column I cut a larger hole and welded a 4" ferrule, lot more work but easier to clean.
FreeMountainHermit
Bushman wrote:On my first build I went with this the set up in the following link: It's easy strong but the downside is it is a bit more expensive.
Trying to understand why you didn't just buy a ferrule and a clamp.
cat herder
Prairiepiss wrote:Take your column and shove it down in there. Now take a BFH and beat it into submission. Making it bend to your will. Now you have a good connection.
BFH.... Big F---ing Hammer?
Prairiepiss
Yessir
Prairiepiss
Ferrules weren't as common back in the stone ages. This kit was high tech back then. Lol
FreeMountainHermit
Stone age ???,...... holy crap. I hope bushman doesn't get a flat on his walker !
cat herder
I have to agree now that I know that the same thing can be built for a handful of scratch.
FreeMountainHermit
If using 2 inch copper go with type M and the ferrule will slip right in. No BFH required.
