Another confirmation question please
Read a shitton of info in Cranky's, Jimbo's as well as other's threads but don't recall off the top of my head what size wire is correct to use from the pot to the SSR..
Sorry if I'm a pest.
Re: Another confirmation question please
It is only a very small signal so any 1mm standard electrical (insulated) cable should do it.
I've used speaker wire (18 gauge), solid copper jumper wire, and telephone wire (22 - 24 gauge) to connect the potentiometers in the controllers I've built...
Thanks again, gents. I was thinking the same thing based on looking at the pictures of the builds posted. Not very scientific on my part but couldn't find any info on wire size. which is kind of strange. Ordered the following:
http://www.ebay.com/itm/201113222022?_trksid" onclick="window.open(this.href);return false;" rel="nofollow
This time next week my boiler will be juiced rather than gassed after many, many years of fun.
Oh, no...!!! That's probably the worst relay you could have chosen, IMHO... There is a current topic where a member is having problems with a controller build using that goofy-footed relay... A simple resistance controlled relay with potentiometer would be simpler, requiring less wiring... Most just have one of the mains entering and exiting and two terminals for the pot to attach to... This one uses both mains and a pot...Blarney Stoned wrote:Thanks again, gents. I was thinking the same thing based on looking at the pictures of the builds posted. Not very scientific on my part but couldn't find any info on wire size. which is kind of strange. Ordered the following:
No flies on this build using same. ?????????rad14701 wrote:Oh, no...!!! That's probably the worst relay you could have chosen, IMHO... There is a current topic where a member is having problems with a controller build using that goofy-footed relay... A simple resistance controlled relay with potentiometer would be simpler, requiring less wiring... Most just have one of the mains entering and exiting and two terminals for the pot to attach to... This one uses both mains and a pot...Blarney Stoned wrote:Thanks again, gents. I was thinking the same thing based on looking at the pictures of the builds posted. Not very scientific on my part but couldn't find any info on wire size. which is kind of strange. Ordered the following:
viewtopic.php?f=85&t=58656" onclick="window.open(this.href);return false;" rel="nofollow
please post a link to a 40A ssr of your liking.Thank you.
My preference would be a PSR-25 or PSR-40... They used to be dirt cheap... Crydom is another brand...Blarney Stoned wrote:No flies on this build using same. ?????????rad14701 wrote:Oh, no...!!! That's probably the worst relay you could have chosen, IMHO... There is a current topic where a member is having problems with a controller build using that goofy-footed relay... A simple resistance controlled relay with potentiometer would be simpler, requiring less wiring... Most just have one of the mains entering and exiting and two terminals for the pot to attach to... This one uses both mains and a pot...Blarney Stoned wrote:Thanks again, gents. I was thinking the same thing based on looking at the pictures of the builds posted. Not very scientific on my part but couldn't find any info on wire size. which is kind of strange. Ordered the following:
Or AC 24-380V SSR-25VA 25A Solid State Relay Resistance Regulator w Heat Sink which is currently $8.92 with heat sink and free shipping... Just add a 500K Ohm 2W potentiometer...
We're posting at the same time
Thoughts ?
http://www.auberins.com/index.php?main_ ... ucts_id=30" onclick="window.open(this.href);return false;" rel="nofollow
Thoughts ?
That unit is DC voltage controlled, not resistance controlled... It would also require additional circuitry...Blarney Stoned wrote:We're posting at the same time![]()
Thoughts ?
SORRY for any confusion on my part. I missed this.Will order in a few minutes if that's fine with you, Sir
http://www.ebay.com/itm/AC-24-380V-SSR- ... 95?_trksid" onclick="window.open(this.href);return false;" rel="nofollow
No problem... You might entertain the idea of ordering from a US based vendor... I, personally, don't like ordering from China or Hong Kong... Sorry for mistakenly providing a link to a vendor from China... Others may not be as preferential...Blarney Stoned wrote:SORRY for any confusion on my part. I missed this.Will order in a few minutes if that's fine with you, Sir
WAAAAYYY out of my comfort zone . Wouldn't know who to contact. You were right about the Craydon be $$$$$ 60- 80 $$$$$ from amozon.
Will do an Amazon search for your recommended SSR.
MANY THANKS FOR YOU TROUBLE, Sir.
Ran my backhoe for 30 years. This computer ^%$@##(*&^stuff is very daunting for me.
Never had this problem with propane.
Rad,I have an acc't with Amazon. So I threw a dart at their board. Fingers crossed.
https://www.amazon.com/uxcell-SSR-40-Si ... B00843J33A" onclick="window.open(this.href);return false;" rel="nofollow
Many thanks.
Many thanks.
Wrong one again...!!! You have got to make sure you are ordering a resistance based unit, not a voltage based unit... You can tell by looking at them if it isn't stated in the description... The one you linked here states 3 - 32 VDC and it should say something like 470K - 560K Ohms... Then you can control it with a 500K 2W potentiometer...Blarney Stoned wrote:Rad,I have an acc't with Amazon. So I threw a dart at their board. Fingers crossed.
Many thanks.
Edited to add: If you have PayPal, order one of the following... The 40A would run cooler...
http://www.ebay.com/itm/24-380V-AC-470- ... OSwx2dYDff~" onclick="window.open(this.href);return false;" rel="nofollow
http://www.ebay.com/itm/SSR-40VA-40A-So ... u23a2a7IQw" onclick="window.open(this.href);return false;" rel="nofollow
Or from Auber Instruments...
http://www.auberins.com/index.php?main_ ... cts_id=353" onclick="window.open(this.href);return false;" rel="nofollow
THANK YOU, Sir. Spent my life on a backhoe so all this is very new to me.
Have PayPal.
Even has a diagram at the bottom of the link for wiring the pot
Many, many thanks to another member here for helping me stumble around HD. He happens to be my neighbor ! None of this would have happened without his and rad's help.
Have PayPal.
Will work with the above diagram ???
Thanks again. Take a nap for me. You probably need one. WHEW !
Sorry for being a pest.
- Snackson
The Auber one is a nice model, but why not just buy from Larry over at http://www.stilldragon.com" onclick="window.open(this.href);return false;" rel="nofollow. You could buy the components separate or all together in a kit. LWTCS aka Larry is a member here. Here's a wiring guide too, https://www.stilldragon.org/uploads/man ... 131020.pdf" onclick="window.open(this.href);return false;" rel="nofollow
Thanks for the wiring guide, Snackson.Will look at Larry's site.
I'm good... I accidentally dozed off while here in the forums this afternoon...Blarney Stoned wrote:Will work with the above diagram ???
No problem. Carry on, Sir.
