6 inch bubble cap glasser
Re: 6 inch bubble cap glasser
Tammuz wrote: Wed Nov 12, 2025 11:18 am I'm glad to see you were able to make your plan come to fruition.
It's slowly getting there. At the moment it's still a work in progress.
One more plate will be added and most likely the cap will be modified so the outlet and cooling lines come out the side instead of up.
For now, I'll run it asis and see how it works and what mods the dephleg need done.
decoy wrote: Wed Nov 12, 2025 12:51 pm I have some here, when do you want to get them?
I want to see this running.
You're not the only one. I'm hoping it will run 6 liters/hour before smearing begins.
Almost time for a water run. The plumbing is done.
The electrics are done and ready to plug in and all that's needed is to fill the boiler and turn it on.
I'll do that tomorrow, tonight I'm going to drink beer instead of working.
Setsumi
Post by Setsumi »
Work never stopped me from having a beer, just saying.
My first flute
My press
My twins
My controller
After a beer or two, I quickly lose the desire to work. :lol:
The boiler being used was built out of a sand filter I found.
viewtopic.php?t=57812
shadylane wrote: Thu Nov 13, 2025 9:28 pm After a beer or two, I quickly lose the desire to work. :lol:
I have that issue too Shady . :lol:
Looks like holding a camera steady is also another side effect :ewink:
The fuzzy pic was partly due to my flip phone camera not focusing under low light conditions and also due to me being temporarily sober.
Did a test run with steam and the plate to glass seals leaked excessively, I'll need to pull the plates and wind more string on them.
I'm guessing on the power but figure the numbers are fairly accurate. The heaters are Camco 02923 4500W 240V
To test the heater resistance, I ran the heater wide open boiling water then quickly unplugged it to measure the ohms while it was still hot.
On both heaters the resistance hot was 13.8 ohms and cold it was 13.2
With 232v measured at the heater the power was 3900w each. So 7800w total.
Only the occasional drip was coming out of the PC with the dephleg cooling valve wide open.
The flow was .7gal/min. inlet temp of 62'f and outlet temp of 132'f
I was too preoccupied by the plate weapage and didn't try turning the flow down but next time will.
Pulled the plates and wound more turns of #3 crochet string, reinstalled and fired her up.
The plates loaded up nice and sweet. But there's still excess weepage past the seals.
#3 crochet string looks like it isn't going to be thick enough and that's the thickest size it comes in.
So I ordered several different sizes of cotton, hemp and jute string to see what works best.
The good news is the DIY gaskets that seal the glass and end caps hasn't leaked a drop. :thumbup:
decoy
Post by decoy »
Hemp rope could be an option.
Is the weeping that big a problem?
Its only on Stop and Restart you have to wait a bit for the plates to flood, once it gets up to pressure it will be fine.
higgins
Post by higgins »
What about PTFE rope? is 3/32" thick enough?
https://tinyurl.com/PTFE-Rope
This one is 10mm (.039"), they have another in 6mm (.23")
https://tinyurl.com/PTFE-Rope2
Salt Must Flow
Post by Salt Must Flow »
higgins wrote: Wed Nov 19, 2025 12:31 pm What about PTFE rope? is 3/32" thick enough?
The first link says the following and not very promising:
Working temperature range: 0 Degree Fahrenheit – 212 Degree Fahrenheit
The 2nd link sounds more promising, but there are funny little errors like grammar and "OC".
The use of temperature -268 ~260 OC
decoy wrote: Tue Nov 18, 2025 10:57 am
Definitely a big problem, the glass is out of round, tapered and thin so I have to be careful about internal pressure.
No hammering the plates in like I could on the 4" glass build.. :lol:
The 1.5mm cotton string came in today. Maybe it will make a pliable enough seal that conforms to the glass.
1.5mm cotton string does a good enough but still leaks.
Interestingly it will hold an almost perfect seal against cold water poured into the column but leaks more with the boiler and depleg running.
Kinda looks like the glass getting hot increases it's diameter enough to cause problems. :roll:
jonnys_spirit
Post by jonnys_spirit »
Might something like fiberglass rope gasket material work? You can get different thicknesses.
https://a.co/d/aYzLsP6
-j
Setsumi
Post by Setsumi »
Shady, I know you were not happy with ptfe. I have good succes with ptfe tape on a thin plate without a rim. Maybe after the cotton string wrap 3 turns ptfe tape.
My first flute
My press
My twins
My controller
Just guessing 3/32" = 2.4mm is close to what's needed.
I'm thinking O-rings would be easier to use than PTFE rope.
If organic string fails to getter done, I'll resort to using food grade silicone O-rings.
Eccentric glass that expands when hot . Can’t say you haven’t tried Shady , thats a tough gig .
Yummyrum wrote: Fri Nov 21, 2025 9:05 pm Eccentric glass that expands when hot . Can’t say you haven’t tried Shady , thats a tough gig .
I haven't given up on using organic string yet, but silicone O-rings checks all the boxes for making the best seal
Call me old school, cantankerous, obstinate or whatever but I'd prefer using something natural.
Tammuz
Post by Tammuz »
Well if you want natural...
Bolverk
Post by Bolverk »
Tammuz wrote: Sat Nov 22, 2025 1:43 pm Well if you want natural
:lol:
I redid the seals using 2mm cotton string and it worked much better than the 1.5mm string.
There's minimum leakage and the power and reflux can be turned down without the plate unloading.
Next on the list is to use silicon O-rings that's 2.5mm thick.
Copperhead road
Post by Copperhead road »
Bump..
Did a sac run and the plates load up as they should, but I don't like this build.
The glass is too thin and irregular for my liking.
Copperhead road
shadylane wrote: Sun Dec 07, 2025 4:28 pm Did a sac run and the plates load up as they should, but I don't like this build.
Did you end up using silicon o-rings Shady??
I left the turns of cotton sting on and stretched a 145mm od X 2.5mm thick silicon o-ring on top the string.
When pushed into the glass, the O-ring laid down between the turns of string and sealed with almost zero leakage.
tommysb
Post by tommysb »
Yeah and who wants to use a puny 6" column anyway, when you could be running on an 8" column instead :lol: !
Copperhead road
Shady is this build considered finished now?
Yes, it's finished and I learned valuable lessons about how difficult it becomes when trying to seal large diameter glass builds. :lol:
That and trying to keep the plates perfectly level using only one tree bolt.
Many years ago I thought about building a six incher using a tree.
Pretty much came to the conclusion that you would need 3 tree bolts minimum to keep things level and stable, four posts would be even better.
Copper column and solder them in is easier I think, it also negates any sealing problems.
Glass looks nice but has its downsides.
