FLUTE TALK
olddog
Re: FLUTE TALK
Post by olddog »
Wow 96ABVThis will be the first Flute to achieve that on a single run, congratulations Wayne. I see it's working as designed :ebiggrin: :ebiggrin: :ebiggrin: :ebiggrin:
OD
Re: FLUTE TALK
Martinnis for everyone :ebiggrin: :ebiggrin:
Yes, been waiting to hear about the 10 plate run.
150 ml of tails,,,,,,,oh mammy that is squeezin it down pretty good.
And 2.2 @ 95,,,,,,,,again,,,that seems like some very good compression.............No stripping,,,,,30 liters in 3 hours with the goodly reflux period included!
How would you describe the size of your stream Wayne?
DOLIKEADRINK
Re: FLUTE TALK
Post by DOLIKEADRINK »
Howdy :)
The stream size was probably from a match stick to a pencil lead, Not quite the size of my pot still stream and maybe a bit under the size of when I run the 4 plater. I have done a few of batches of Hook Rum with the 4 plater and it smells amazing and I don't like Rum, But I recon I might just have a couple when it is aged this stuff just smells so Bloody clean. I haven't even tasted my UJSSM yet :cry: I am trying to let it age nice and slowly no touching for 3 months min, Shit it's hard but when it smells so bloody good, Lucky I have a good supply of my Pot Still UJSSM :)
Cheers: Dolikeadrink
"Your putting on the agony but missing all the style" Ya want a good Still PM olddog
likkerluvver
Re: FLUTE TALK
Post by likkerluvver »
DOLIKEADRINK wrote:Howdy :)
..... I have done a few of batches of Hook Rum with the 4 plater and it smells amazing and I don't like Rum, But I recon I might just have a couple when it is aged this stuff just smells so Bloody clean. I haven't even tasted my UJSSM yet :cry: I am trying to let it age nice and slowly no touching for 3 months min, Shit it's hard but when it smells so bloody good, Lucky I have a good supply of my Pot Still UJSSM :)
I somehow lost the first part of my earlier post, :oops: so here are: My congrats on the 95+% on the Birdwatcher's in 10-plate mode. The rig sure is an impressive build, with lots of versatility.
I am wondering how the cleanest neutral (the 10-plate config. can produce) will compare with that of a Bok or a VM when shooting for azeotrope?
I look forward to hearing more about the flavour carry-over in 4-plate mode in due time - how it compares with your previous pot-stilled rum and UJSSM product.
All sounds good so far. :)
LL
Having fun stillin' seriously..... This antique engine runs best on high octane.
Austin Nichols
Re: FLUTE TALK
Post by Austin Nichols »
I ran a BW wash a few days ago trying to make a neutral from 5 plates.
After airing for 48 hours it's pretty good.
thepatchworkdoll
Re: FLUTE TALK
Post by thepatchworkdoll »
Hey Austin
Is that a 5 plate sieve still or bubble cap. That reading on the alcometer is sound.
Regards
Thepatchworkdoll
DOLIKEADRINK
Re: FLUTE TALK
Austin Nichols wrote:I ran a BW wash a few days ago trying to make a neutral from 5 plates.
Hey Austin how did your neutral taste from 5 plates :?: That looks like 96% to me :D What temp was the sprit :?: I got OLDDOG to put a temp port in my Parrot like the one you made, Great simple idea well done.
likkerluvver
Re: FLUTE TALK
Hey guys,
It all looks pretty impressive. AND on just 5 plates AN. WOW :D
:?: Keep us posted on the flavour carry-over (where you WANT it (heavier rums, whiskeys, etc.) as compared with straight pot-stillin' - when you have a chance. :?:
LL
Austin Nichols
Re: FLUTE TALK
Distillate temp was 21.3c, I have to run my coolant inlet line through a bucket of iced water because my tank water is at 28c.
It tastes ok, not brilliant, but pretty good, I had to run pretty slow with lots of reflux to bump the ABV up tho.
Edit: to add, it's got 5 perforated plates.
prdbrissy
Re: OLDDOG'S 10 PLATER
Post by prdbrissy »
DOLIKEADRINK wrote: I dropped my temp gauge into my parrot that olddog made for me (one of his new design) it worked like a treat no surging at all, The temp was 24.7 dropped in my alcometer :shock: 95% straight away :D Holey snapping duck shit batman far out :D During the run I saw 96% it actually floated between 95% and 96% throughout the whole run.
DOLIKEADRINK was this in pot sit mode or was there some reflux going on?
Regards
My continuing Flute build story is here- http://homedistiller.org/forum/viewtopi ... 17&t=19556
Re: FLUTE TALK
@PB
Definitely not pot mode with all 10 plates in the line up.
And ikm pretty sure a bit of forced reflux is requisite to keep the perf plates loaded
Running with no reflux would prolly only get you into the early to mid 80s
valkyrie99
Re: FLUTE TALK
Post by valkyrie99 »
Asking for opinions about design. My column is 24 inches long and im using 4 plates. What im wondering is how much below the deflagmater should the top plate be? Would there be an advantage or disavantage to lowering them some or just putting it 4 or so inches and leaving the extra at the bottom in case i want to add another plate later.
Thanks for your thoughts on this. Valk
The older I get the better I was.
olddog
Re: FLUTE TALK
Post by olddog »
valkyrie99 wrote:Asking for opinions about design. My column is 24 inches long and im using 4 plates. What im wondering is how much below the deflagmater should the top plate be?
4-5 inches, the same as the gap between your plates. :D
OD
prdbrissy
Re: FLUTE TALK
Post by prdbrissy »
OK we are nearly there.
This is it in it's shortest mode. One column section and two plates ( I have not made the rest yet) I can't wait I must give it a go.
You could say I am going to learn to play my flute one note at a time.
Tomorrow morning I will do a cleaning run and if time permits I have a sugar wash ready to go.
All the bits
assembled
Regards
olddog
Re: FLUTE TALK
Post by olddog »
Let us know how your flow meter works out with a Flute.
BTW Great looking build, can't wait to here the results of your first run.
OD
Re: FLUTE TALK
Yes, really good looking build.
There are a bunch of really well put together builds round here. Really has raised the bar this last year
What kind of sugar wash PB? Got any kind of adjunct in it so you can gage your flavor?
Ah no matter,,,I'm sure it will be as it should.
exon
Re: FLUTE TALK
Post by exon »
Very impressive PBY !
Great looking work.
exon
I am a pathological liar and functional illiterate.
Re: FLUTE TALK
Real nice craftsmanship, prdbrissy... I especially like the modified keg top... Looking forward to hearing how the rig works when completed...
Prairiepiss
Re: FLUTE TALK
Post by Prairiepiss »
Great looking build prdbrissy.
1 question? Am I not reading your post right or am I missing something? You said this is the smallest configuration with one column section and two plates. That's where I got lost. Are you going to be running two plates? If so where will the second one be placed? I know the one will be between the bottom reducer and the column section. Is there enough room under the dephlagmater for the second plate to be placed on top of the one column section you have?
Or were you just saying you had two plates built?
I do know that you will be adding more column sections and plates as you get them built. My question above is just about the above-mentioned post that said you were going to run it like this.
prdbrissy
Re: FLUTE TALK
Post by prdbrissy »
Prairiepiss wrote:Great looking build prdbrissy.
There is a plate at each column joint. Therefore in this configuration there is a plate above and a plate below the window( sight glass). The dephlegmater condenser starts about 75mm up from the column section joint.
I did the cleaning run this morning. I have a small water leak in one of my water lines to fix and I think I will reduce the size of the holes in the plates from 2.5mm dia to 1.5mm dia before I run the wash. Unfortunately that want be till next week now.
Regards
Prairiepiss
Re: FLUTE TALK
Oh ok I thought the dephlagmater started at the joint. Sory I was confussed!
RayDean
Re: FLUTE TALK
Post by RayDean »
Finally starting to make some progress!
Machining done on 4" to accept the stainless ferrules.
Main column off to the welder. I know the sight glasses are too long, but it's hard to argue with free.
Dephleg cooler dry fitted
Condenser dry fitted.
WalkingWolf
Re: FLUTE TALK
Post by WalkingWolf »
Nice work RayDean -- it is nice to see I'm not the only one that resorted to getting a machinist to cut down the damn copper for the ferrules to fit. Look forward to hearing how it turns out for you.
WalkingWolf
Re: FLUTE TALK
Ah Spook -- that shit bout had me giving up on the column all together. I guess I got the thickest copper cause they weren't even close. They weren't even close even after working on them for several hours with a file. Was happy as a clam after I got them cut -- He left them 5'thousandths or so undersized (or something like that). I had to tap them pretty good to get them in but it went really well.
Mr.Spooky
Re: FLUTE TALK
Post by Mr.Spooky »
after my last flute build,,, i had about 20 hours with a hand file :shock: ,, that aint hapinin again.... i went to get a 4" ferreul welded to a keg today and the owner of the shop called me back and said " we have a problem,, the kegs aluminium",,, i thought to myself,, bullshit, ,so i told him to check his facts.. as it would have it,,, its S.S!!!! recon his fabricator just thought that a beer keg was made out of the same stuff as beer cans :roll: .. anyway,,,, i guess the moral to my story is no matter wich path ya take,, theres gonna be somekinds of stones in the road :|
spooky
RayDean
Re: FLUTE TALK
Post by RayDean »
Thanks for the encouragement guys, I needed it. Everythinghas been really smooth sailing so far, but tonight I started on the sieve plates. I've gone so far as to center punch all if the holes, but after breaking 4 bits without a single successful hole through all 4 plates I'm thinking that I've exceeded my talent level. Thinking about going back to my original plan of a valve tray using rivets.
prdbrissy
Re: FLUTE TALK
Post by prdbrissy »
RayDean wrote:I've gone so far as to center punch all if the holes, but after breaking 4 bits without a single successful hole through all 4 plates I'm thinking that I've exceeded my talent
Drill the holes in one plate then use it as a template to drill thru another and so on. Dip the drill in water before drilling each hole.
Regards
Kentucky shinner
Re: FLUTE TALK
Post by Kentucky shinner »
I drill them 2 at a time.. Use some WD40 spray your bit just a little while your drilling go slow and dont force your bit.. Let it do the work. You will be fine.
olddog
Re: FLUTE TALK
Post by olddog »
Using a drill press, I have done up to 6 at a time, you have just got to take it steady and have a sharp drill bit.
OD
Austin Nichols
Re: FLUTE TALK
olddog wrote:Using a drill press, I have done up to 6 at a time, you have just got to take it steady and have a sharp drill bit.
OD
I tried and failed with the drill press OD, had brand new bits too, but my plates were 3mm thick.
Ended up drilling them out one plate at a time, one hole at a time, seemed like 300,000 holes :lol:
