Jimbo's Electric Conversion
If it plugs in, post it here.
Jimbo
Re: Jimbo's Electric Conversion
Post by Jimbo »
OK folks, here's some stats on how this baby runs. Just finished the first stripper run.
I loaded in about 12 gallons of 8% ABV wheat AG and threw on the coals (the wash was about 66F). Measuring 240V at the element it was the full 5500W the element can produce. It took 36 minutes for the run to start and 44 minutes for a full heavy stream. Thats less than half the time it took me with my propane burner roaring.
As things settled in and stabilized I was pulling quarts at 5:10 minutes a piece :shock: yes thats too fast, even for a stripper. My 40" leibig knocked it down just fine, but did need a faster water rate than typical, definitely not a trickle. Here's some measurements -
12gal 8% wash
36 min to run start
5500W 5:10 per quart
4000W 8 min per quart
3000W 12:15 per quart
The entire run took me 2:15. Much faster than propane. About half the run was at 3000W and then I bumped it to 4000W and ran at 8 min/quart to finish up. The wash was somewhat cloudy, squeezed it off the grain only yesterday so it settled some but not completely. No signs of scorching whatsoever. For the spirit run I expect Ill be down around 2000W give or take.
All said, I couldnt be happier. No propane expense, fumes, door open when its 10F out, just the hum of the element doing its thing and the fan on the controller box keeping things cool. Also ran all the way down to 10%, ended up with 2.7g right at 30% avg.
Cheers.
corene1
HD Distilling Goddess
Post by corene1 »
Jimbo wrote:OK folks, here's some stats on how this baby runs. Just finished the first stripper run.
12gal 8% wash
36 min to run start
Cheers.
Outstanding! :clap: :clap: :clap: . I did a 7 gallon stripper yesterday and it took about the same amount of time using my propane setup, and I have never been able to put out enough heat to get to a quart in 5 minuets. I am sold for sure.
humbledore
Post by humbledore »
That is amazing Jimbo...can't wait to get my electric up and running. Even though I am starting small with 110v and a quarter barrel. Thanks for this thread.
bellybuster
Post by bellybuster »
every time I run my electric setup I wonder why I ever even tried propane.
I am now in the process of converting my all grain brewery in to electric.
Congrats Jimbo, enjoy'er
ezlle71
Post by ezlle71 »
I have a quick question, i got a copper i inch slip to 1inch npt adapter. i cut the slip part off so the wavy part of the element would fit thru it. Do you guys think a copper coupling like this would be strong enough to use for a element in a keg? I am planning on using sliver solder and a oxy acetylene torch. Having a hard time finding stainless couplings locally. On a high note i did get a ulwd 5500 watt camco wavy element from a local plumbing wholesale place for 22 bucks!!
ez
Don't let your meat loaf.
Jimbo
Post by Jimbo »
Several folks have PM'd me asking about how this is wired. I drew this up, hope it helps.
For the Keg side dont forget to ground the keg itself. I drilled a hole in the bottom skirt to attach ground. See below. Also dont forget to ground the control box also, its easily missed in the drawing above.
Cheers,
Jimbo
Prairiepiss
Post by Prairiepiss »
12gal 8% wash
36 min to run start
Cheers.
Congrats.
I think you will be closer to 1000w for your spirit run. Give or take.
corene1
Post by corene1 »
Thanks for the wiring diagram. I am thinking of putting in an amp meter also. probably don't need to as I should be able to do the calculations with voltage draw,but I amstill a little hazy on electrics. Thanks again for all the help.
Jimbo
Post by Jimbo »
I made you a chart :ebiggrin: . Am meters are more of a pain cause there's a shunt to wire in. Not the end of the world tho.
Halfbaked
Post by Halfbaked »
This is what mine looks like. The part I am not pleased with is it is 12 volt so I had to get a 110 to 12 volt converter. Can't tell you whether I like it or no cause I have not put it together yet. My thinking when I did it is I could put every number down on paper and it would be accurate where ever I was.
Due51
Post by Due51 »
Thanks for the thread Jimbo. I've read as many threads on electric conversion as I could find and my head was spinning. I live in Michigan and didn't want to use a turkey fryer-type propane burner with my keg and Boka. I am somewhat clumsy and envision a disaster waiting to happen. Your thread has helped me immensely.
I ordered the SCR controller and will get the coupling and element next. I still have some questions:
1) do you have a picture of your coat hanger coil and rubber electrical tape enclosure for your element?
2) How did you ground out the box with the SCR?
3) I'm still unclear on how to wire in a fan.
Sorry if these are repetitive. I've literally spent this entire work day (plus with a few others) reading on this subject. I fear the unknown when it comes to something as critical as 220volt electricity.
Thanks again.
Due
Those who stay...
Jimbo
Post by Jimbo »
Thanks Due, yes you need Due diligence when horsin with high voltage. :P
I dont understand your first question, rubber electrical tape enclosure for the element? wassat? There are pictures in the original post I made here. It shows the element and the box.
The box is grounded with a screw through thebox, ground lugs on all the neccesary wires and nuts to hold it all tight. See bottom left corner in the 2nd picture.
The fan is wired exactly as shown in the wiring diagram just below to a 12V power supply. The power supply is wired to Hot1 and Neutral (to make 120V), the output is 12V and powers the fan and voltmeters.
Due51
Post by Due51 »
My apologies. It just re-read page 1 and it was S-cackalacky who fashioned a wire hanger and rubber insulating tape to cover the end of the element where the wires attach.
Thanks again.
Those who stay...
marshrunner757
Post by marshrunner757 »
Jumbo, what size wire are you using? I got my SCR in and those terminals look awful small. Also, are you using single or multi strand wire?
Jimbo
Post by Jimbo »
The terminal blocks on those cheap Chinese SCR's are too narrow to accept a standard 10 guage ring lug. :crazy: :tired: :x I had to grind the edges of the ring lugs to fit. The wiring is mostly 10AWG except for the stretch from the breaker to the box which is 8AWG. All wiring is multi strand.
Due51
Post by Due51 »
I have a question about home wiring:
(If this hijacks the thread, let me know and I'll create a new thread)
I have 8ga wire going from a double pole 40amp breaker at the box, right over my brew station, on its way to the A/C compressor. What if I cut that wire and installed a 220v socket on the end leading to the box and a male plug end on the wire leading to the compressor? Then I could unplug the compressor and plug in my 5500w heating element when I want to distill.
Thoughts?
Those who stay...
marshrunner757
Jimbo wrote:The terminal blocks on those cheap Chinese SCR's are too narrow to accept a standard 10 guage ring lug. :crazy: :tired: :x I had to grind the edges of the ring lugs to fit. The wiring is mostly 10AWG except for the stretch from the breaker to the box which is 8AWG. All wiring is multi strand.
Thanks Jimbo
Due51 wrote:I have a question about home wiring:
Thoughts?
Theoretically, yes...
S-Cackalacky
Post by S-Cackalacky »
Due51 wrote:My apologies. It just re-read page 1 and it was S-cackalacky who fashioned a wire hanger and rubber insulating tape to cover the end of the element where the wires attach.
Thanks again.
Sorry, I just saw this and will try to respond. There are probably much better methods than using the coiled wire hanger. You can find non-metalic wire stress relievers on ebay, or you could use a small juction box to house the wiring connections on the element. With the method I used with the wire coat hanger, there's always the danger of it coming into contact with the element terminals and causing a short. I very carefully wrapped the wiring and terminals with the rubber insulating tape before putting on the coiled coat hanger. and then applied the same rubber tape over the full length of the coil. Although, if I had it to do over again, I would probably use the small junction box method.
The tape - I bought at Lowe's. It's like rubber and has a backing that you have to peel away when you use it. You apply it like you would regular electrical tape, but it bonds together and becomes a solid piece and acts as an insulator. Sorry, I don't remember the brand name. You will find it in the same electrical isle section with the electrical tape. I'm sure you would find it a most any hardware store.
S-C
Due51
Post by Due51 »
Just bought a 1" stainless coupler and had my customer drill a hole and TIG weld it in for me at no charge. Of course, I dropped off Lions tickets, a half gallon of booze, McLures spicy Bloody Mary mix, and Saunders Hot Fudge as a Christmas gift, so we'll call it even. Ha.
Those who stay...
bellybuster
Due51 wrote:Just bought a 1" stainless coupler and had my customer drill a hole and TIG weld it in for me at no charge. Of course, I dropped off Lions tickets, a half gallon of booze, McLures spicy Bloody Mary mix, and Saunders Hot Fudge as a Christmas gift, so we'll call it even. Ha.
Sounds like he did a really, really good job.
xbwqs78
Post by xbwqs78 »
Any thoughts on using this for a connector
HEX BUSHING 150# 304 STAINLESS 11/2 X 1 NPT <786WH
http://www.ebay.com/itm/HEX-BUSHING-150 ... 518f23d4e7" onclick="window.open(this.href);return false;" rel="nofollow
Cut a hole thread it on and then silver solder it?
bellybuster
I'm sure that'll work. If I were to do mine again I'd use these
http://www.brewhardware.com/fittings/120-spuds
xbwqs78
Post by xbwqs78 »
Sold, that is what I will go with. Thanks Belly!!
Jimbo
Post by Jimbo »
Dont bother with those blue backlit chinese voltmeters I posted. Mounted them up today. At full voltage they measure fine, as the voltage drops they are not even close at 170V (measured on my expensive Fluke meter) they read 118. They are way off everywhere but full voltage and zero.
I spent a couple hours cutting the holes in the box, now I got meters mounted up that are pretty when lit up but worth 2 shits for reading voltage.
Damn this, I think Ill pour a drink or 3 and order a pizza.
sambedded
Post by sambedded »
Jimbo wrote: as the voltage drops they are not even close at 170V (measured on my expensive Fluke meter) they read 118. They are way off everywhere but full voltage and zero.
It's because your Fluke shows True RMS voltage but that "blue" shows average of the rectified waveform. They calibrated to show same voltage as True RMS but only for sine waveform. Since output from Phase Angle controller has sine waveform only on full power you will always see a difference n reading.
All voltmeters under $20-$30 and even many more expensive ones will give you the same wrong reading.
Jimbo
Post by Jimbo »
No kidding. Well shit. Thanks Sambedded. I'll have to throw that on a scope and see what it looks like. I guess an ammeter is better for this afterall? Or will that reading be hosed too?
sambedded
Post by sambedded »
you will have absolutely same issue with ammeters too. But i wouldn't worry to much. Yes, reding is incorrect but it consistent (unless your mains voltage doesn't fluctuate too much).
Jimbo
Post by Jimbo »
Well that was embarrasing. Seems I should have known that being an engineer, must have slept through that class. Ill blame too many years doing small signal stuff.
Here's a new chart. i used my fluke to measure true RMS then wrote down the avg readings youll get with the cheap meters.
Thanks again Sambedded.
Jimbo
Post by Jimbo »
for those you buying these cheap SCR's, note they need to be under load or they just show full output voltage regardless of knob setting. If you wire it up and check it dont panic. Put enough water in your boiler to cover the element and plug in the SCR. Everything will start working as expected.
Dont ask me how I know this.
