power controller fan
If it plugs in, post it here.
stillvodka
Post by stillvodka »
I am fitting a fan in my pinto controller, I bought a computer fan but only just realized it is 12volt, so I will use transformer and incorporate it in the enclosure/box , I know this is a simple question for most, but the fan has three wires Black-Red-Yellow , power from transformer leads to the black and red turns the fan on, would the yellow be the earth ?
Re: power controller fan
stillvodka wrote:I am fitting a fan in my pinto controller, I bought a computer fan but only just realized it is 12volt, so I will use transformer and incorporate it in the enclosure/box , I know this is a simple question for most, but the fan has three wires Black-Red-Yellow , power from transformer leads to the black and red turns the fan on, would the yellow be the earth ?
That might be a variable speed fan... Most single speed fans only have red and black... The yellow usually feeds through a temp sensor either on the system board or elsewhere... Should either run full speed or not at all without the yellow connected... It appears as though the yellow line gets +V from 0-12V to trigger fan speed, but design specifications vary...
stillvodka
Thanks Rad,
Yes your right, connected red black full speed red yellow runs lot slower
I will admit I am not up on electronics, but pretty good following instructions, I about to Finnish wiring up controller to live but have hit a snag, with pintoshines kit you get two power leads, Black and white, I am guessing Black live/white neutral, is this correct ?
snuffy
Post by snuffy »
That is correct. Black is hot.
the third wire on the fan is often a speed signal so the temp controller on the computer knows how fast it is spinning. Either way, black (-), red (+).
I wish I had left room for a fan when I built mine. It doesn't get hot enough to do any damage, but it does cause the pot to change values as it warms up, so I have to watch the dials to make sure it hasn't turned itself up....
Time's a wasting!!!
stillvodka
Snuffy
Why don't you cut the side out the enclosure and attach a fan, built in a separate box, piggyback', I have my fan in there for reason of removing hot air from inside the control box, it's not fitted like for a CPU attached to the heat sink, when I had my Sultronics controller it did get really hot with nothing but a heat sink to cool it.
PartingGlass
Post by PartingGlass »
Sorry to bring this one back from the dead, but I felt it was better than starting a new/similar thread.
Before I had ever tried my controller (large DIY kit from Still Dragon (http://stilldragon.com/index.php/diy-la ... oller.html" onclick="window.open(this.href);return false;" rel="nofollow), I assumed the heatsink would get hot so I ordered a 220V / 150mm fan from eBay. After using it a few times, I'm not convinced that it runs hot enough for a fan, but since I've already got it, I've decided to mount it up. My only question is how to wire it up? It's got 2 wires, and I'm confused on where the wires should go; maybe the electrical gurus could point out the numbers my (crude) drawing?
Just guessing here, but I'm thinking I can hook the + wire from the fan to either the "in leg" of the ammeter (orange box on top left) or #3. Then the - fan wire could connect to either of the greens on the SSR, right?
Fan specs:
150mm x 150mm x 50mm
220/240V
rated current - 0.1A +/- 10%
speed - 2600 RPM +/- 10%
airflow - 240 CFM +/- 10%
Will I need anything else (such as a speed controller) to wire this up? If I find that 2600 RPM is too fast/loud/etc, how would I go about slowing it down a bit? If I wire the fan + to the #3 terminal mentioned above, will the speed be somehow controlled by the pot like the amperage for the element?
Thanks in advance.
controller box.png (9.57 KiB) Viewed 1533 times
Goodnight, and joy be with you all
Deerhunter
Post by Deerhunter »
I would wire the fan to your on/off switch if you have one. The switch should be a DPST (double pole single throw). You need a hot on each side of the fan.
Sky Diving without a parachute is a once in a life time experience!
PartingGlass
I've got an on/off switch, but I haven't installed it (didn't think I needed it after I got it), but it's a DPST 2-position, 4 terminal switch rated at 15A/250V.
At the moment, in lieu of a switch, I just turn the pot all the way down before plugging in / unplugging the controller.
Deerhunter
You are correct with that switch DPST. I was wrong. But I would get that in 30amps.
