CO2 danger?
- Coyote
CO2 danger?
Ok guys I have not found an answer to this.
I set up my new "man cave" which is an old 16' X 8' X 8' tall walk in cooler
Walled off 3 feet in the back, insulated, installed a door, lights and heat
Even at 10 below zero it is very easy to keep the room at 76-78 degrees
My rolling fermenter rack will hold 12 - 7 gallon fermenters
In addition I have a 55 gallon food grade barrel set up on rollers
My question is this: with the possible amount of CO2 off gassing
what should I be concerned with?
As I remember from HS science class CO2 is heavier than O2.
Do I need to worry about venting?
Should I employ a floor level exhaust fan?
Just don't want to walk in to the fermenting room one day and get hit
square in the face with a CO2 baseball bat
Your thoughts are eagerly awaited
Coyote
Coyote
Re: CO2 danger?
Id be more woried about the heating, than that of the fermenter. even electric burns up o2.
- Coyote
Re: CO2 danger?
The Man Cave is pretty tight but not air tight
Space under the main door,ect.
Keeping the fermenter room at 76- 78 degrees the rest of the
building stays about 55- 60 ish.
Have to open the main door more than a crack when cooking a mash
or running the still as the temp will jump into the 85 to 90 range
pretty darn quick - about 45 minutes to see it climb to 80 degrees plus
with an outside temp of 20 degrees
Re: CO2 danger?
Opening the door to the back section should introduce more than enough air to dilute any buildup of CO2 that might accumulate... I wouldn't add additional ventilation at the expense of needing additional heat... If you're really concerned just leave the main door ajar when you first open the back section, but I doubt that this will be necessary...
- Coyote
Re: CO2 danger?
Thanks Dunderhead and Rad
As we all stress on here Safety First
Quick Robin to the Man Cave!!!!
Re: CO2 danger?
""you could throw the cat in there first , if he falls over dont go in"
if you dont like the co2 in there, run a blowoff tube outside.
- Coyote
Re: CO2 danger?
Not that I don't like it
Just wondering about the safety aspects
of that much off gassing
Re: CO2 danger?
The amount of CO2 coming off a regular size hobby ferment probably ain't much more than from a couple of people breathing normally. A small vent or two should be plenty.
Be safe.
Be discreet.
And have fun.
Be discreet.
And have fun.
- LWTCS
Re: CO2 danger?
Dnderhead wrote:""you could throw the cat in there first , if he falls over dont go in"![]()
- Teddysad
Re: CO2 danger?
Why not introduce a couple of larhe leafed house plants.
They'll grab that CO2 and introduce oxygen
Make you feel more tropical too!
I suggest NOT cannabis sativa though
You can lead a horse to drink, but you cant make it water!
You can lead a horticulture but can you teach a prototype?
Proverbs 31:6-7
Proverbs 31:6-7
- Teddysad
Re: CO2 danger?
whoops should have said large! ( must be the sippin takin effect
Proverbs 31:6-7
Proverbs 31:6-7
- heynonny
Re: CO2 danger?
dnderhead said
-hey man, what are canaries for??-hey-""you could throw the cat in there first , if he falls over dont go in"
Re: CO2 danger?
Canries are for singinheynonny wrote:dnderhead said-hey man, what are canaries for??-hey-""you could throw the cat in there first , if he falls over dont go in"
Besides the fn cat got the canary already.
these are cheap insurance on evil bay.
Carbon Monoxide(CO) Meter DY881
I.Feature:
# Easy to read 6999 count backlit displays carbon monoxide gas levels from 0 to 1000ppm
# Record logging (3 sets)
# Visible and audible alarm >= 40ppm
# Zero point adjustable, gas provision stored permanently
# Auto power off, data hold, low battery warning
# 3.7V 650mAh Li cells employed, recharging anywhere
I drink there for I am.
I mrink there for I ad.
I .... oh gorfet et.
Re: CO2 danger?
Drunkmore: You maybe confusing Carbon Monoxide with Carbon Dioxide. Monoxide is oderless and lethal. Dioxide is inert and heavy (forms an invisible layer on the floor). Monoxide (like from car exhausts) will form a complex with the haemoglobin in your blood so it can't carry oxygen to your brain and you get cherry red coloured lips, and will quietly slip unconcious and die. With Carbon Dioxide (like from your ferment) if you were in high concentrations you would suffocate because of the exclusion of oxygen. But long before this you would experience hypoxia with respiratory distress and be heaving for breath. You would obviously leave the container and leave the door open for a few minutes while the CO2 flowed out. If this was me I don't think I would be worrrying about this or installing a vent that would take your heat out and possible let vermin in.
