parrot
DCT
parrot
Post by DCT »
any link for a step by step build on a parrot?
thanks
cornwhiskey
Re: parrot
Post by cornwhiskey »
DCT wrote:any link for a step by step build on a parrot?
thanks
The most successful distiller should be able to build from a picture. Screw ups and fixes are inevitable. I've been homebrewing for years and and recently started distilling. I built my still from looking at different pictures and truly understanding how a still works. And for the record I am not a handyman and never soldered anything until a couple of months ago. Search parrots on this site and build your own based off of a single picture or design your own after looking at multiple pictures. It's just some copper and solder. Good luck.
Re: parrot
I've gotta agree with cornwhiskey on this one... Step by step instructions shouldn't be required for most stilling related hardware... If you can't think on your feet while building in the workshop what are the chances of being able to think on your feet during a distillation run...???
View... Understand... Put solder to copper... This hobby doesn't require precision measuring with a tape measure, micrometer, laser level, and inclinometer... Close enough will generally suffice... My other half has a Harley Davidson Tee shirt which reads "If I have to explain, you wouldn't understand"... In short, it's a seat of your pants kinda thing by nature...
olddog
Re: parrot
Post by olddog »
Here's one for you to copy, use 1" tubing for the alcometer tube to prevent hydrolic effect giving a false reading.
OD
DCT
Re: parrot
Post by DCT »
ok, I can do this, one question is there a pipe within the 1inch?
thamks
olddog
Re: parrot
Post by olddog »
No thats where your alcometer goes. :roll:
cob
Re: parrot
Post by cob »
dct click on olddog's parrot picture, hope you have broadband :D
cornwhiskey
Re: parrot
olddog wrote:Here's one for you to copy, use 1" tubing for the alcometer tube to prevent hydrolic effect giving a false reading.
OD
That is one fine looking parrot. All shiny and sleek looking.
Ayay
Re: parrot
Post by Ayay »
The product goes into the funnel, down to the bottom of the 1" and fills it. There floats yer alcometer. After filling the 1" the product overflows into the cup and out through the parrot beak in a continuous flow. The alcometer floats accordin to the % alc in the 1" as the product flows through it. There's nothing more than what you see on the outside :)
DCT
Re: parrot
Post by DCT »
got it, thanks for the help, now im going to go build me one fancy parrot....will post a pic when finished
DCT
Re: parrot
Post by DCT »
ok, been teaching myself to solder, getting the hang of it & is kinda fun. question
what do you use to clean parrot with & how to check for leaks? also i got a flat sheet of copper & hints for making a funnel???
im pissed i got ripped by the turbo stomper guy, think i can build my own still, will keep practicing on parrots...lol
thanks for getting me motivated!!
olddog
Re: parrot
Post by olddog »
To make a funnel, mark and cut out a half circle on a sheet of copper, mark the center on the flat side, and then curl each half together to form a funnel. you then solder the two edges together, and cut off the point to match the diameter of you feed pipe, and then solder to your feed pipe.
OD
Re: parrot
DCT wrote:think i can build my own still
Of course you can. Your butt joints look better than mine.
Soak in some vinigar and put the wire wheel on the outside.
olddog
Re: parrot
Post by olddog »
A wire wheel will mark, use medium grade steel wool.
DCT
Re: parrot
Post by DCT »
ok to run threw dishwasher?
olddog
Re: parrot
Post by olddog »
I wont hurt it.
Re: parrot
I do like the milled look the fine wheel makes on tubing. Plus it can expidite some of the solder runs.
But I can't hardly debate this with the beautiful art work that old dog builds.
WalkingWolf
Re: parrot
Post by WalkingWolf »
That's what I'm talkin 'bout D C T.
You done stepped up and got some "doin' it" goin' on. I'm with you on the turbostupid (sp??) still. I got one too. I have run it a half-dozen times and the pot is now cracked at the top rim. I'm waiting for the sum-bitch to fall apart mid run and drop the load of charge over my stove. :lol: :esurprised: . Good thing I'm finishing up my new rig and have a keg for a boiler. Good luck on the build.
I learned to solder as I rebuilt my still. It's funny how after you get a couple pieces of copper together and looking half decent, all of a sudden you start to thinkin', "Hey, I can do this 8) ".
Good Luck
WalkingWolf
DCT
Re: parrot
Post by DCT »
ok that damn mother f-ing funnel was tuff, my 1st on was a bust, the 2nd on I got right, just tested it & no leaks....wow im proud of my self, now i just hope my alcoholmeter dont bottom out, its on order, probably should have waited untill i had it, but think i had enough room, over 12 inches, not sure how long those typicaly are? i will post a pic soon of my finished parrot & 1st solder job!
olddog
Re: parrot
Post by olddog »
12" is fine, just put a bit of scrubber at the bottom, it will stop you cracking your alcometer when you drop it in.
OD
DCT
Re: parrot
Post by DCT »
ok, thanks olddog.....here it is...like my first child...lol
DCT
Re: parrot
Post by DCT »
my funnel
WalkingWolf
Re: parrot
Looks good DCT -- your a "quick" study. I see a real still in your future grasshopper :ewink:
WalkingWolf
DCT
Re: parrot
Post by DCT »
my second parrot, thought i was creative, but just found a simillar design on here, im going to hammer out a custom bowl from sheet copper....for a old body man this copper is getting addictive, cant wait to start distilling.
olddog
Re: parrot
Post by olddog »
You gotto be carefull when you start building things out of copper, you can get addicted to it. :mrgreen: :mrgreen: :mrgreen:
ozone39
Re: parrot
Post by ozone39 »
I put a 1/4" turn ball valve at the bottom so I can dump my fore/head shots out....Just an idea....
WalkingWolf
Re: parrot
Kool 8) Ozone.
Pretty neat idea. Does it work as well in practice as it seems in principle??
WW
ozone39
Re: parrot
Post by ozone39 »
As long as you're paying attention :egeek: . I put a graduated cylinder under the valve and wohla, no head shot content in the bottle. :D ...
blanikdog
Re: parrot
Post by blanikdog »
Nice idea, ozone. Well thought out.
blanik
Cumudgeon and loving it.
blaireau
Re: parrot
Post by blaireau »
Parrot of two friends,
