Copper scrubbers
NO1DLR
Copper scrubbers
Post by NO1DLR »
Does having copper in a still make the the alcohol much better than ceramic rings or stainless scrubbers, assuming that the ABV is the same?
kiwistiller
Re: Copper scrubbers
Post by kiwistiller »
some copper somewhere in the system is desirable as it tends to strip out sulpher flavours. doesn't have to be packing though.
Three sheets to the wind!
My stuff
kiwistiller wrote:some copper somewhere in the system is desirable as it tends to strip out sulpher flavours. doesn't have to be packing though.
+1
Copper in the vapor path is a definite plus...
NO1DLR
Post by NO1DLR »
I don't need much copper though in the condensor do I? Will a 1cm layer of scrubbers be enough?
Samohon
Post by Samohon »
NO1DLR wrote:I don't need much copper though in the condensor do I? Will a 1cm layer of scrubbers be enough?
I put 1 SS Scrubbie inside the coil and 1 that I use as a sock on the outside.
It helps centralize the coil so that the distillate is falling into the center of the packing...
♦♦ Samohon ♦♦
