Graham condenser sizing
How do you go about sizing a graham condenser? It seems most are using 3-4" pipe as the housing, but can you go smaller? What is the determining factor, the size of the inner coil? Also could you go for a smaller housing and stretch out the length?
Re: Graham condenser sizing
The diameter of a Graham condenser is governed by the size of the coil for vapor condensation.
OD
Yes it would then be a Leibig condenser.kenfyoozed wrote:Also could you go for a smaller housing and stretch out the length?
OD
- LWTCS
Recon there are some round here that likes the math and can figger such things.
I was trying to find something to do with the remainder of some 4". I wanted my condenser to kinda match my tower.
Also wanted something that could not be overwelmed with a hobby heat source.
By contrast, Rednose put together an "egg" sized product condenser for his Bok.
2" jacket with a 3/8 coil alah liebig style would offer a goodly amount of surface area.
There is a condenser calculator on the parent site that can help in calculating the required size of liebigs and worms... A Graham condenser is merely a spiraled liebig so use that option and you'll get pretty close on size requirements...
