As always, I charge the keg with about 15 litres of wash, chuck in the copper boiling chips and a tablespoon of oil. Had to use extra virgin - maybe the inexperience caused the problem lol
Sealed it up, fired up the 3 ring and started to do a bit of tidy up while waiting for the fores to start. Same as I do every time, never had a glitch.
I usually get a bit of chuffing for about a minute and then it settles into the strip run.
Not this time. It was pissing out.
I turned the gas bottle off and it kept pouring out for about another 3 minutes. This is after a quick cleanup.
All up it puked about 6 litres in the blink of an eye. I had to flush the coil, the lyne arm and rinse out the parrot. Not to mention cleaning the table and mopping the floor
I put a new seal on and started again. I wasn't going to chance another puke, so I ran the start into a bucket.
All was good. As always, a bit of chuffing at the start so I turned the inside ring off to drop the heat a smidge and away we go.
This is why you need to be on your toes. It's not a game.
scarecrow
