Hello from Vic AU
Grehund
Hello from Vic AU
Post by Grehund »
HI Guys,
I've been lurking around these forums for the last few weeks learning all I can, in preparation for making my first still. Initially I was going to purchase a T500, but after reading HD I've decided against it in favour of making my own. I've spent the last couple of days purchasing tools & materials & I've almost finished my column. To save me some time & effort, I decided to buy a T500 boiler to attach my custom 2" Bok column to.
Now, I'm again scouring the HD forums to find the best fittings to use for the column-boiler connection. I really want something that is easy to change, because I plan on building some extra length into the column later on, or attaching a better column.
I know this is only the Welcome Centre, so I'll place my specific question about the flange in the appropriate section.
Column: Bokakob, 50mm Diameter, 1035mm High, Copper
Packing: 720mm High, Stainless Steel Scrubbers
Boiler: 25L capacity, 1800W heater (no heating control), Stainless Steel
yankeeclear
Re: Hello from Vic AU
Post by yankeeclear »
Welcome to the forum Grehund!
Love the enthusiasm. I am new also and will look for your other posts to share what I have learned so far.
Have fun and stay safe.
“Half the lies they tell about me aren't true.”
-Yogi Berra
Grehund wrote:HI Guys,
Welcome to the forum. To connect the column to the boiler on a keg I use this fitting. You can probably price it out a little cheaper but she works great. http://www.milehidistilling.com/Stainle ... /16608.htm" onclick="window.open(this.href);return false;" rel="nofollow
Not sure what you need for the T500 I guess I should have a closer look at the set-up, but sometype of tri-clamp seems to be a lot sturdier than other ways to rig the two together.
Mud Mechanik
Post by Mud Mechanik »
Welcome aboard, try this site. http://www.hillbillystills.com/category_s/43.htm" onclick="window.open(this.href);return false;" rel="nofollow
Prairiepiss
Post by Prairiepiss »
He's not connecting it to a keg guys. More like a cooking pot lid. And shipping would kill him from here in the states. I don't know what the connection on the lid of a T500 boiler is? Maybe someone around here can help with that? But you could always go with a simple slip fitting and use either flour paste or PTFE tape to seal it. Something like used in this build. http://homedistiller.org/forum/viewtopi ... 46&t=13598
Good luck be safe and remember we like pics.
Edited to fix my link.
Grehund
Post by Grehund »
Hi Guys,
Wow, thanks for the replies! :wave:
Prairiepiss is right, the T500 boiler isn't a keg or keg fitting. It's actually just a hole in the SS lid!
The hole has a diameter of approx 48mm, the lid has a recessed section about 60mm in diameter. The T500 column has a screw & nut fitting on it that secures it to the boiler.
I was thinking of getting a similar type of connection for my coulmn, but I don't know what they're called or where is best to buy them from here in Vic AU.
I have had mixed results at both Bunnings & Reece Plumbing with this project. :cry:
You could always convert it over to use Tri-Clamps...
Grehund
Post by Grehund »
I was really hoping NOT to have to solder SS. It's looking like I might be out of options.
Scotty72
Post by Scotty72 »
Hi,
I'm new around here (from Sydney, NSW) ... and I had exactly the same idea (and the t500 boiler) as you...
How did it go?
Scotty
Grehund
Post by Grehund »
Hi Scotty72,
Welcome to the forums. Sorry for a delay in getting back to you. :oops:
I haven't made the move to a SS Tri-clamp yet, but I think it's the best method.
At the moment I'm using a series of brass fittings to attach the SS T500 Lid to the column. My exact Bill of Materials for this section were:
1x 50-40mm Nipple Reducer
1x 50mm Tube Bush
1x 40mm Lock Nut
Here are some pics, so you can get an idea of what I did.
T500 lid & 2" Bok column, assembled.
2" Bok column with soldered Nipple Reducer & Tube Bush assembled.
Lock Nut
Lock Nut
Bayou-Ruler
Post by Bayou-Ruler »
welcome
Bayou Ethanol
Ethanol Fuel Producer
AFP-LA-15027
http://www.BayouEthanol.com" onclick="window.open(this.href);return false;" rel="nofollow
