Hope some knows how to help
mash rookie wrote:Stainless welds and or brazing are all fine. I often MIG and TIG stainless using stainless wire or rod. You can use silicon bronze rod to TIG stainless to copper. It is safe. The only solder that will work with stainless is Silver solder so no issues there either.
Go forth and build !!!!
MR
Stainless wire and a tri mix of Helium, Argon, and CO2nwvapors wrote:
Hey MR how do you MIG stainless? I have a MIG welder but I was under the impression I couldn't do a decent stainless weld with it. Are you using a specific gas/wire combo? If this could save me from investing in another tool I would be very appreciative.
NcHooch wrote:Stainless wire and a tri mix of Helium, Argon, and CO2nwvapors wrote:
mash rookie wrote:The guys are fast. They have answered your question.
Yes, you use a tri mix helium gas and stainless wire. It works great. No, Really great. The helium gas is very hot so it makes for a very sweet weld. Easy!
I keep a stainless mix bottle and change out gas and wire when I want to weld stainless. I like it better than TIG welding stainless. That is probably because my MIG skills are better. I will use my TIG to clean up some welds sometimes.
TIG welding is often referred as "Gentleman’s welding" because of the ability to do delicate welds. TIG's basically melt metals together. “TIG Torch” Great for some things like welding corners together where you can run down the weld melting two pieces together. When doing more conventional type of welding where material is added like welding rod or wire feed TIG’s take more skills. Stick or MIG apply material as you arc.
TIG is more like torch welding where you have to add filler rod as you proceed. Except you cant pull back the flame quite as easily. I have great respect for guys that are TIG masters.
You will love MIG stainless!!!
Thanks MR I'll have to give it a go, a little more investment in tooling but lot cheaper than a TIG unit for sure.![]()
MR
I don’t think we are hijacking Bull. This is a welding thread.Bull Rider wrote:Mash:
(not trying to hijack this thread)
I have a Lincoln 175 (220 volt) MIG welder. I use the CO2/Argon mix and solid core wire.
If I picked up a bottle of straight argon, and a pound of stainless wire, then I could MIG stainless?
Any way to MIG stainless to copper? I've done it with Oxy/Acet, but that was a long time ago.
Bull.
I am holding my breath in anticipation, always love to see your creations!mash rookie wrote:(Wait until you see that new design)![]()
You are a TIG Master. It is tougher than it looks.johnhopper1957 wrote:With TIG if you want stainless to copper use 316 stainless filler wire, copper to copper use copper filler wire and I have had no problems with argon. You need to be quick with copper as soon as you see the weld pool form be ready to start your run real quick. You also need a lot of amps.
...Sorry, I'm from DenmarkDnderhead wrote:if your speaking of the mettle ,no all you do when welding is to melt the base mettle and at times add filler of the same or close to the same as the base mettle.so if it was safe to start with, then its still safe.with stick/intersheld yes as they use flux that needs to be removed.
as with any mettle all has to be cleaned well as they use oils and chemicals in manufacture.
...Are you here refering to a vineager run,...or is there some other way, I have to clean it alsoDnderhead wrote:yes corrected on spelling,, intersheld and stick use flux. stick is the older type of welding where the wire is covered with flux.. intersheld has the flux inside of a tube and fed threw a gun much like MIG.either of these are generally used on thicker metals but can be used on thinner stock if no other way is available.both of these need to be well cleaned.TIG (tungsten,inert gas) and MIG (metallic inert gas) both need less cleaning.
