First mash
First mash
Ok so I have been reading for a couple months and I got all the stuff I ordered to make my first wash.
I have:
55 gallon fermenter
100 lbs of sugar
Yeast 10x packs of EC-1118
Starter nutrients geothermal
Regular nutrients fermaid O
Ph strips
Hydrometer
Stirrer and syphon
I have:
55 gallon fermenter
100 lbs of sugar
Ph strips
Hydrometer
Stirrer and syphon
Re: First mash
I still don't have a boiler or column or heating unit or heating controller or coolant pump.
I have some friends with a cm from brewhaus if I don't get one in time, I have a couple quotes out to get someone to make me vm with a boka top. I live up north where it's cold and I figured get my. Ash going them when it's done put it on the deck and pull off the ice for a few days. While I am working out the rest of the details.
Re: First mash
Wow! You don't believe in doing things in a small way, do you?Arphaxad wrote:Ok so I have been reading for a couple months and I got all the stuff I ordered to make my first wash.
I have:
55 gallon fermenter
100 lbs of sugar
Ph strips
Hydrometer
Stirrer and syphon
Btw, if I have it right then those ingredients make a wash, rather than a mash.
She's only a whisky maker but I love her still.
Re: First mash
Lol I can't seem to figure out the difference between a mash a wash or I my case a mess. Or a must... Are all these terms specific.
So far I have got 80 grams of fermaid o and about 20 lbs of sugar dissolved in boiling water.
I am trying to get the yeast started in another container with geotherm.
I also have citric acid powder but I havn't used ay yet. Currently wash is 4.6 ph. Not deep enough yet to check the hydrometer.
Re: First mash
grains are mashed... and make mash.
sugars make wash. sugars can be molasses or cane juice or agave nectar... whatever, its a wash...
must is from fruit. Crushed grapes are called must.
Don't forget to invert your sugar! Add citric acid to the boiling sugar water to invert sugar. Look up how much to add real fast... This helps the yeast better utilize the sugars.
this is the internet
Re: First mash
I found mt citric acid powder ...
Re: First mash
I would suggest something other than just those nutrients. Maybe some tomato paste like Birdwatchers recipe. Which is what you should have set out to do to begin with.
But good luck. Hope it works for you.
Re: First mash
I am shooting for 1.080 specific gravity, ph of 4.5 50 gallons , temp 90 f ish. ..
You think I should add tomato paste I have 3 cans in the cupboard
Re: First mash
Do it ![Thumbup :thumbup:](./images/smilies/icon_thumbup.gif)
Re: First mash
I would. That's a lot of sugar to waste. If it doesn't work out. I hope for your sake it does work.Arphaxad wrote:I am shooting for 1.080 specific gravity, ph of 4.5 50 gallons , temp 90 f ish. ..
Re: First mash
Well I got 1.080 I got 4.8 ph I got 50 gallons fluid ... I got 100 f and I pitched 25 grams of ec-1118 and 80 grams of fermaid o and. 25ish grams of geotherm.
Golly I didnt measur e the citric acid.. But I used it and some baking soda to balance the ph
Re: First mash
My wash has cooled down to 82F and the hydrometer is reading 1.090 oops I was shooting for 1.080
Re: First mash
My temp has dropped to 70.1 F and my specific gravity is still 1.090 it's still bubbling like ginger ale but I expected it to start dropping already.
Is it ok that the hydrometer hasn't moved yet, 36 hours into it?
Re: First mash
Lol now lets not go speaking common sense lol
Re: First mash
Ok it has been 4.5 days or 108 hours my temp is holding steady at 67F and my hydrometer is reading 1.079.
It's going a lot slower than I expected.
Should I throw in more yeast? It's still bubbling like ginger ale.
Re: First mash
Get that wash about 10 degrees warmer...
Re: First mash
I can if you think I should it's ec-1118 and the specs looked like it did best at 70F if I was interpreting them correctly.
Re: First mash
From here the optimal range is between 15C and 25C, so it will be fastest to be close to 25C (77 degrees F).
2" Bokakob (1 foot with 4 foot reflux extension), Pony keg, and propane
Re: First mash
I have a logistical question for you. You mentioned storing this finished wash outside. How are you planning on moving a 55 gallon drum mostly full of wash? I don't remember who said it here, but some of the best advice was to enthusiastically avoid picking anything up over 4 gallons. Your back will appreciate any attempt to heed it.
I'm not satisfied, and that's exactly why I'm so optimistic."
-Wendell Baker
-Wendell Baker
Re: First mash
Yeah I should have bought the wheeled dolly first.
It weights about 400lbs. I can slide it myself and I have a 4' wide slidding glass door right off the kitchen. To the deck. A little ramp and I should be ok.
Not the brightest idea I ever had.
Re: First mash
I built a three wheel stainless steel cart for my 40 gallon fermenter. Good casters are essential when your volumes get much over 10 gallons... ![Laughing :lol:](./images/smilies/icon_lol.gif)
Re: First mash
Specific gravity of 1.070 temp 67.6F. Still bubbling away.
I read that the lower the temp you ferment at the less off flavors, is this true?
And can someone tell me what a troll is in reference to posting in forums? I have seen the term and I am not quite sure I get it.
Re: First mash
Arphaxad- every yeast has a high and low temperature tolerance. At the higher temp regimes, the yeast are working faster and are not as efficient at doing their job and may produce off flavors. At the lower end of the spectrum, they are able to work slower and are therefor more efficient.
A "troll" is someone who joins a forum posing as a novice and asks questions that they know will get a rise out of forum members--just to mess with them.
Re: First mash
Lol that's kind of funny about trolls. Rofl what a waste of time.
Re: First mash
Well I ended up buying a wheeled dolly to make moving it easier. It was kind of stuck around 1.030 so I wheeled it over next to the stove and bout the temp from 67F to 74.8F.
After it hit temp I wheeled it back into the kitchen after a couple days it hit 1.000
Last night I had some friends help me get it out on the deck.
My 26 gallon boiler should be arriving Monday I think. I ordered it jan 27th.
As soon as I get the boiler I am taking the top to a master plumber who is going to build the still part.
I am planning on doing a 3" boka over a VM.
I am tempted to get the 6 plate flute from hillbilly stills.
I still need to get coolant pump and build the phase controller for the heater.
I will keep ya all posted.
Re: First mash
Wow thats complicated. Really like your optimism on having four hundred pounds of wash and the plumber aint built the still yet. You got me so tickled I nearly spit ethyl acetate all over the compooter screen.
Re: First mash
Lol.
My boiler came and boy is it a beauty.
So here is a question ... I put this out on my porch and my wash is now 10.8 F and it's still liquid.
I thought it would freeze and I would be able to pull out a few chuncks of ice bringing the ethanol content upwards of 20%.
When I look at ethanol freezing points it would appear that I may be closer to 18ish %. Unless the left over sugar and fertilizer is having a large impact. It's got a pretty good kick compared to wine in my opinion.
Any thoughts on how to get this to freeze.
Not a whole lot left of winter here.
