New to here
wallyb23
New to here
Post by wallyb23 »
i am new to this forum, hope to learn more than i know, witch is not the most. got a batch fermenting right now. hope it comes out nice.
August West
Re: New to here
Post by August West »
Welcome to the forum, safe stillin,
AW
If you waste your time a talkin' to the people who won't listen to the things you've got to tell them, who do you think's gonna care?
Samohon
Re: New to here
Post by Samohon »
Welcome...
Have a great time here at HD, safely ofcoarse... :thumbup:
♦♦ Samohon ♦♦
Re: New to here
Welcome to HD, what recipe you making? Is it one from the forum or did to obtain it elsewhere?
heartcut
Re: New to here
Post by heartcut »
Welcome.
heartcut
W. H. Auden
Prairiepiss
Re: New to here
Post by Prairiepiss »
Welcome aboard.
What kind of still you running?
wallyb23
Re: New to here
Post by wallyb23 »
i am making a recipie i got from a buddy of mine. and i have a 3gal single top. i got about 6 gal of mash going right now.
pfshine
Re: New to here
Post by pfshine »
Welcome to HD.Have fun be safe and read read read the info is here just look
Prairiepiss
Re: New to here
Whatsa 3 gallon single top?
wallyb23
Re: New to here
Post by wallyb23 »
not sure of the name of it, but it kinda looks like the on in the forums top left corner
Re: New to here
Share recipe, and lets see some pictures! :D
wallyb23
Re: New to here
Post by wallyb23 »
heat 5 gal water to 170 degrees
add 8.5-9 lbs crushed/ flaked corn( this one is not feed quality)
remove from heat stir for 5-10 min constantly
:eugeek: watch temp and stir on and off till 150 degrees
stir in 1-1.5 lbs crushed malted barley( can add suger if like( i tried with out sugar))
let sit till temp falls to 100 degrees
add yeast ( i did turbo 48) let sit for time stated roughly 5 days
if you have heard of this one let me know or if you have tried it let me know how it turns out.
:thumbup:
Prairiepiss
Re: New to here
wallyb23 wrote:not sure of the name of it, but it kinda looks like the on in the forums top left corner
Ok sounds like a pot still.
Re: New to here
wallyb23 wrote:heat 5 gal water to 170 degrees
:thumbup:
Nope... There is no place for turbo yeast in a grain mash, with or without additional sugar... Turbo yeast is engineered to be used with straight sugar washes because the product also contains more than enough chemical nutrients to feed the yeast throughout a rapid fermentation...
As for your still, is it a simple pot still or a "World Class Home Distillation Apparatus" reflux column which isn't really all that great...??? Does it have cooling tubes passing through the column...???
wallyb23
Re: New to here
Post by wallyb23 »
i got two things...
1. is the mash going to be ok to go with or should i restart it?
2. it has a cooling tube around the end and a inlet and outlet for a waster hose.
i hope i didnt screw the mash up.
wallyb23
Re: New to here
Post by wallyb23 »
here is my pot still
wallyb23
Re: New to here
Post by wallyb23 »
i ran the a little of the batch. it ran good and i got 111 proof out of it.
