Dilution Water Calculator
This calculator is helpful in accurately determining how much water is required to dilute a given volume of alcoholic spirits at a known strength down to a desired strength. Any standard values can be used for the calculations just as long as they are consistent. For example, quarts, liters, ounces or milliliters as well as %ABV or proof can be used. The calculators default values are in milliliters and proof. Also note that the calculator labeling was worded so as to be a reminder that alcohol should be added to water, not water added to alcohol, to help reduce the possibility of clouding the resulting mixture.
Re: Dilution Water Calculator
This is awesome and exactly what I am looking for!
"You only have power over people so long as you don't take everything from them. Once you've robbed them of everything, they're no longer in your power. They're free again."
Aleksandr Solzhenitsyn
- Husker
This calc has been added to the bottom of the 'rad14701' page on the parent site (calculators).
http://homedistiller.org/calcs/rad14701" onclick="window.open(this.href);return false;" rel="nofollow
H.
H.
I wasn't aware that there is actually another calculator that also serves the same purpose on the Product Dilute Calc page...
I thought I had checked for one but didn't look close enough...
Nice Addition Rad...
♦♦ Samohon ♦♦
Hee, been usin it foreverrad14701 wrote:I wasn't aware that there is actually another calculator that also serves the same purpose on the Product Dilute Calc page...I thought I had checked for one but didn't look close enough...
...heck you prolly wrote that one too
thanks
NChooch
This is great Thank you !!!!
All of them are very helpful, thank you!
