Is blue normal!
Is blue normal!
Ok so i did a vinegar and water run and things went well now on to my mash run and the liquid coming out is blue is this from the copper? Or what could i be doing wrong?
Re: Is blue normal!
i am using a reflux pot still i made. also wash is wheat, rye, and malt
Re: Is blue normal!
did you use any alkaline in your wash?
Re: Is blue normal!
Dnderhead wrote:did you use any alkaline in your wash?
Nope the only other things i left out was sugar and yeast and that was all i used
Re: Is blue normal!
I sure whould not drink it..
Re: Is blue normal!
haha wasn't planing on it..... Just need to know what not to do for next time. or if i should run it through again when finished or just quit for today
Re: Is blue normal!
I did throw some on a fire and it seems to be flammable... so if all else fails i have a fire starter recipe!
Re: Is blue normal!
Did you rinse it out good after the vinegar run. Did it sit for a length of time before you ran the sacrificial alcohol run? And what exactly is a reflux pot still?
Re: Is blue normal!
no it did not sit long at all my guess is it is from the copper and the first time or something after letting it run a while it started comming out clearer and not it looks like water. i attached a few pics to show i think it is called a boka or something
Re: Is blue normal!
Yes thats a LM reflux still.
So you did a vinegar run.
You didn't rinse good.
You ran and alcohol run.
Is that how it went?
Re: Is blue normal!
that sounds like how it went. i am guessing it is oxidation from the still?
Re: Is blue normal!
It's oxidation from the vinegar (acid) you didn't rinse out good.
Re: Is blue normal!
Mprourke, This is off topic but you should really look for a better place to collect your product. On top of that hot boiler over an open flame is looking for trouble. Now on topic... Did it ever get clear later on in the run? Or did you collect in that one bottle? If it was from oxidation on the fresh copper it would probably clear up after you get a patina going inside the still. I would treat it like yellow snow and not ingest
Take a look at your coil and see if it has a tint to it or down your column. Was your column packed? If so was the packing pure copper or stainless steel? Some copper scrubbies are only copper plated. Let us know what you find, and good luck to ya.
![Wink :ewink:](./images/smilies/icon_e_wink.gif)
Re: Is blue normal!
The blue tint is copper sulfate, it is toxic. It is from running the vinegar and not washing out your still. The high acid content and copper during distillation create the byproduct.
"Sometimes too much drink is just barely enough." ~ Mark Twain
Re: Is blue normal!
""The blue tint is copper sulfate""
close but not quite,,,copper+acetic acid= copper acetate
Re: Is blue normal!
yes it did clear up.... i ran it through a brita and looks clear but i dont know prob shouldn't drink well next time i will make sure i was every thing after vinegar wash!
And yes the column was packed with copper netting the the coil at the bottom was alittle discolored
Re: Is blue normal!
If you go read the cleaning a new still thread. You will see you shouldn't drink the first alcohol run anyway. It should be your sacrificial alcohol run. That thread van be found in the must read new distiller reading lounge.
And a brita shouldn't be used for spirits. Maybe do a search around here for that to.
Re: Is blue normal!
Mprourke, you didn't try putting baking soda in your wash before distilling, did you...??? It's alright to use small amounts in the wash during fermentation but adding after fermentation is complete is problematic...
Re: Is blue normal!
Unless it is added to previously stripped low wines, in which case some believe that it helps to compress and reduce the quanity of heads in your runrad14701 wrote:Mprourke, you didn't try putting baking soda in your wash before distilling, did you...??? It's alright to use small amounts in the wash during fermentation but adding after fermentation is complete is problematic...
![Very Happy :D](./images/smilies/icon_biggrin.gif)
Re: Is blue normal!
Yes, but only if left to do it's magic for a week or two prior to redistilling... Adding it to the boiler charge is less than beneficial...frozenthunderbolt wrote:Unless it is added to previously stripped low wines, in which case some believe that it helps to compress and reduce the quanity of heads in your runrad14701 wrote:Mprourke, you didn't try putting baking soda in your wash before distilling, did you...??? It's alright to use small amounts in the wash during fermentation but adding after fermentation is complete is problematic...
Re: Is blue normal!
But Rad, there's them that argue that it works best added to the boiler where heat can speed the chemical reaction rather than waiting a longer time at room temp. What makes you say adding to the boiler is no good? (not being a dick - would love a link for more info as i've read of people doing it both ways like i said. Hell, i've done it both ways!)rad14701 wrote:Yes, but only if left to do it's magic for a week or two prior to redistilling... Adding it to the boiler charge is less than beneficial...frozenthunderbolt wrote:Unless it is added to previously stripped low wines, in which case some believe that it helps to compress and reduce the quanity of heads in your runrad14701 wrote:Mprourke, you didn't try putting baking soda in your wash before distilling, did you...??? It's alright to use small amounts in the wash during fermentation but adding after fermentation is complete is problematic...
Re: Is blue normal!
if its not your sacraficial run you can re run it
