DO NOT DRINK ANY SHINE THAT COMES OFF OF THE STILL BEFORE
THE TEMP REACHES 69 DEGREES CENTIGRADE.
2.DO NOT DRINK ANY SHINE THAT COMES OFF OF THE STILL AFTER
THE TEMP REACHES 95 DEGREES CENTIGRADE.
3.DO NOT UNDER ANY CIRCUMSTANCES DRINK ANY SHINE AFTER
YOUR TEMP HAS REACHED 97.5 DEGREES CENTIGRADE
IF YOU DO NOT FOLLOW THESE RULES YOU WILL KILL YOURSELF END
#2 My still sometimes doesn't produce until I have reached 200f Sometimes I drift into the 95celsius-203.0F
# 3 What happens at 97.5 Celsius/207.5?? All I know is by this time I'm deep into tails 20 percent tails
All I can see that is going on in higher temps is your alc content is decreasing thats why you need to bring temp up. Also if I hit 212f I'm going to get water vapor.
Any truth in this post on a random site I stumbled on???
- Odin
Re: Any truth in this post on a random site I stumbled on???
Well, it wont kill you if you do. I think what the writer tries to bring over is ... seperate heads and tails from your middle run in order to get a better, head and stomach ache free drink. My advice: do some reading on making cuts.
Odin.
Odin.
sounds like something that was written during the prohibition.
esp wrote:DO NOT DRINK ANY SHINE THAT COMES OFF OF THE STILL BEFORE
This sounds like the ramblings of a 14 year old Facebook poster.
Scrapper
As you can see I was up pretty late last night... Enjoying this forum. Sometimes I do searches for recipes and found it. I had to ask out of curiosity because I have never read about any of those rules / guides to follow on this forum or any where else for that matter.
Below is where I found it
http://www.oocities.org/napavalley/vine ... shine.html" onclick="window.open(this.href);return false;" rel="nofollow
"ITEMS:
1. ONE BIG GLASS JUG 5-10 GALLONS SHOULD D0. I LIKE TO USE
GLASS AS MUCH AS POSSIBLE DO TO THE COPPER THAT IS NOW
BEING SOLD HAS A LOT OF IMPURITIES IN IT AND MAY PRODUCE
DEADLY SHINE!!!!!!!! "
" TAKE THE RUBBER STOPPER AND DRILL THREE HOLES INTO THE TOP
OF IT WITH A 1/4 INCH DRILL BIT. THEN TAKE THE TWO GLASS TUBES"
There is load of misinformation scattered all through that page.....
Scrapper
Stop reading ignorant bullshit scattered across the internet and do ALL of your research here on the HD site...
Problem solved...
Problem solved...
God I hope Some young kid dont try and do that.
