Copper supply in U.S.A.?
Does anyone know of a food grade copper supply in the u.s.a.? I need a sheet approx 3 foot by 5 foot. Thanks.
Re: Copper supply in U.S.A.?
Hi, i'm not in the US but i've seen that a member here KYChemist is building a new pot with new sheets of copper, maybe if you look through his posts there will be a supplier mentioned.
Hth
Cheers
Stainless
Hth
Cheers
Stainless
Luceo Non Uro
Thank you stainless
mcmaster.com
Away with yer pills, it'll cure all ills, Be ye Pagan, Christian or Jew,
so take off your coat and grease your throat with a bucketful of Mountain Dew.
I'm not aware of there being such a thing as "food grade" copper... Most new copper sheeting is pure enough to be considered food grade...
Not sure there is such a thing as food grade copper? Copper is copper.
Hahahahaha
and three sheets to the wind is ?????
cheers
stainless
cheers
stainless
Luceo Non Uro
Hi there,
I think my question fits this topic.
What pipe should I choose?
Here is what I found:
CMC Howell Metal 2" x 10' Type L Copper Pipe Item #: 139914 | Model #: L TUBING
2-in x 10-ft 174 PSI Copper Pipe Item #: 140679 | Model #: 6360932759802
Cambridge-Lee 2" x 10' Type M Copper Pipe Item #: 369252 | Model #: 308758
Thank you!
Thank you!
Hi, not being in the US i would say that if you can get copper tube 2"x 10ft, i would ask them to cut into 2 or 3 separate pieces before shipping. Long tubes tend to get damaged very easily in transit. Hth
Cheers
Stainless
Cheers
Stainless
Luceo Non Uro
Thank you for the suggestion.Stainless wrote: i would ask them to cut into 2 or 3 separate pieces before shipping.
Cheers
Stainless
These are available in retail.
I am not sure about the copper Grade: Type L or Type M is there any difference?
Thanks again.
What that refers to is wall thickness, for our needs you can get by with dwv, which I believe has the thinest wall. And would be the least expensive..
If your on the west coast, an outfit called Alankan Copper has lots of stock..
Last edited by Stainless dude on Tue Aug 13, 2013 10:23 am, edited 1 time in total.
Hi
@SD. i was thinkin it was wall thickness, or weight by length, same in steel, you buy it by weight. Not by section form or sheet, it all works out to cost the same.
by weight !
Hth
to the OP
buy what you can get at the best price available.
wall thickness won't make too much diffrence on a hard strippin run, thinner wall will get to temp quicker
by weight !
Hth
to the OP
Luceo Non Uro
OK.
Now it makes sense.
Thank you all!
Now it makes sense.
Thank you all!
