voltage regulator for heat control
If it plugs in, post it here.
rehrlich
Post by rehrlich »
Can anyone tell me if this would work? Its a 3800w 0-220v voltage regulator light dimming speed temperature controller. It about half the price of the variable speed router and it already has a heat sink. Was thinking about getting this for my electric hot plate (1100w). I think this would be a better option than the router speed controller. Any input would be appreciated
2014-01-21 18.21.54.png (397.29 KiB) Viewed 2857 times
Prairiepiss
Re: voltage regulator for heat control
Post by Prairiepiss »
There are a bunch of threads about them around here already. They will work.
rehrlich
Post by rehrlich »
So this will work as is? Simple as hooking up the cord and plugging it in. Do you think its better than a router speed controller
That unit is essentially the same as a router speed controller aside from the fact that it is lacking the snubber circuit, an additional resistor and capacitor (and sometimes an inductor coil), that inductive loads require...
bellybuster
Post by bellybuster »
you still need to bypass the thermostat in your hot plate.
S-Cackalacky
Post by S-Cackalacky »
rehrlich wrote:So this will work as is? Simple as hooking up the cord and plugging it in. Do you think its better than a router speed controller
You could do that, but it would be much safer to install it in a box. If you just attach the wires and run it that way, you will have the danger of exposed wires and electrical shock. There are many threads describing controller builds here on the forum - search and read.
S-C
piratekev
Post by piratekev »
I am wanting to use this w/ a digital meter, fan and an on off switch all to control 1 220 volt heating element.
Is a schematic available or this build?
Tokoroa_Shiner
Post by Tokoroa_Shiner »
Yes there is. Search for SSR controller. Or google it. Easy to find
The Rules By Which We Live By
Safety And Related Issues
New Distillers Reading Lounge
