Keg Polishing
Keg Polishing
Anyone have a rock solid procedure to do a pretty decent keg going in?
Don't just throw it together. Take the time to build it right....
- Truckinbutch
Re: Keg Polishing
Just my own opinion : keep the inside clean and do your polishing on your product . Shined shoes don't have much influnce on where the feet in them are headed .
Re: Keg Polishing
I used auto polishing compound and a buffing machine(slow moving side grinder) with buff pad.
Worked real well but it will sling compound so wear an apron.
OLD MAN IN THE SHED
Re: Keg Polishing
Yep Bentjar is right lots of work and lots of mess but worth it if you take pride in your gear. I use a pedestal buffer, start with sisal buffs then move to cotton. Use ss black compound.. In tight spots I use a 6" wheel on die grinders..
Re: Keg Polishing
4" angle grinder with gator pads from Lowes. And polishing compound from harbor freight. Start with a course pad work down to a fine pad. I used the course compound with the fine pad. Then the polishing pad and compound. Working a small area at a time. Took me a good three days of hard work for one keg. I will never do it again. It was a build for someone else.
Re: Keg Polishing
She's a beauty P, nice!
Re: Keg Polishing
I've got a shiny spot on one of my kegs. Started then said Fug it
Re: Keg Polishing
I never even started on mine. And said the same thing.bellybuster wrote:I've got a shiny spot on one of my kegs. Started then said Fug it
I would probably do it again. If I was building for someone else. But mine can keep looking like hell.
Re: Keg Polishing
Prairie, is that blue 55 gallon drum you fermenter or coolant holding tank?
Those who stay...
Re: Keg Polishing
I gotta say P that is fine . Is the ring on the floor the ring off the keg?
Re: Keg Polishing
Sugar storage. Have another one for grain storage. The fermenters are to the right of that pic. There should be some pics of them in this thread.Due51 wrote:Prairie, is that blue 55 gallon drum you fermenter or coolant holding tank?
http://homedistiller.org/forum/viewtopi ... =2&t=35751
Halfbaked yes it is. I cut the bottom ring off. Used it for the foot. With 1" angle for legs. flipped the keg upside down. Used the sanky as a drain and added a 4" and 2" to the top. One for fill and one for column. Then a 2" on the side for an element. It's a really nice setup. Wish it was mine.
- Cardinalbags
Re: Keg Polishing
Mine was sooooooo shiny that it almost made me blind.....
So i hid it under a bunch of insulation......
My new still:
http://homedistiller.org/forum/viewtopi ... 50&t=44544
My old still
http://homedistiller.org/forum/viewtopi ... 6#p7083991
My controller:
http://homedistiller.org/forum/viewtopi ... 9#p7089109
My old still
My controller:
Re: Keg Polishing
Mine is so dull/ugly, no one says anything about it living on my deck!
DSP-AR-20005
DSP-AR-20005
Re: Keg Polishing
I am new to distilling, but very old to polishing.
Realistically, I could make a keg awesome looking in 15 mins or less, but I have a 10HP machine in my shop.
For folk at home, I would use either a hand grinder (if you have to) or a hand polisher (if you can, it's basically a grinder with more torque), any spiral sewn wheel 6-8", and some high shine compound. Don't worry about removing the scratches, just go for shiny. It will look good in pics and from 3+ feet away, if you did a decent job.
"Gonga Gonga" -GA flatpants
Re: Keg Polishing
I would like to see someone polish a used keg in 15 min.
Re: Keg Polishing
Did you see the 10HP part? Seems the biggest challenge would be hangin on to the damn thing with that many horses buffing away.
Re: Keg Polishing
was looking but can't find it. There was a video of a guy polishing a keg on a large metal lathe, the keg was spinning and he was using a huge buffer. That sucker was shinin within a minute. Now... if I can only find that giant metal lathe and chuck in the garage.....
Re: Keg Polishing
Jack your truck up. Pull a wheel off. And bolt it to the axle. Lolbellybuster wrote:was looking but can't find it. There was a video of a guy polishing a keg on a large metal lathe, the keg was spinning and he was using a huge buffer. That sucker was shinin within a minute. Now... if I can only find that giant metal lathe and chuck in the garage.....
- Location: Somewhere to the north of the.. ..Peoples Яepublik of Kalifoяnia
Re: Keg Polishing
Hmmmmm, ......I know a guy that uses a very large lathe and special built cutting tool to molest kegs into keggles! I'll have to see if he'll let me "borrow" his lathe for a polishing job.bellybuster wrote:was looking but can't find it. There was a video of a guy polishing a keg on a large metal lathe, the keg was spinning and he was using a huge buffer. That sucker was shinin within a minute. Now... if I can only find that giant metal lathe and chuck in the garage.....
Re: Keg Polishing
I was thinking the same thing. 420hp to the rear wheels big block chevy.. Hell, you could do 2 kegs at once, lolPrairiepiss wrote:Jack your truck up. Pull a wheel off. And bolt it to the axle. Lolbellybuster wrote:was looking but can't find it. There was a video of a guy polishing a keg on a large metal lathe, the keg was spinning and he was using a huge buffer. That sucker was shinin within a minute. Now... if I can only find that giant metal lathe and chuck in the garage.....
Re: Keg Polishing
You know what's funny? After all the running my mouth about being a professional metal polisher and blah blah blah, I'm sitting here looking at my dirty old keg and all the dirty pre-soldered copper pipes and parts like :/
You know the mechanic who drives the Chev POS?
Or the glass guy with poly taped in where his side window used to be?
That's me right now. I had all these grand plans of before/ after pics to show y'all.
And now? :/
And now? :/
- ga flatwoods
Re: Keg Polishing
Tis true more work than most janitors are used to doing. Especially if it turns out gleeming! Hard to clean a torazzo floor without stripping waxing and buffing. If a year old sour mop wont clean it to hell with it! Sick mentality.
GA Flatwoods
GA Flatwoods
I am still kicking.
Ga Flatwoods
I am still kicking.
Ga Flatwoods
Re: Keg Polishing
All that polish don't make good liquor.
Using Google Search
Using Google Search
- ga flatwoods
Re: Keg Polishing
So, neither can janitor!
GA
GA
I am still kicking.
Ga Flatwoods
I am still kicking.
Ga Flatwoods
- Cardinalbags
Re: Keg Polishing
Two at once is the recommended method actually, unless you want to run after the truck with your polisher in handHusker wrote:I was thinking the same thing. 420hp to the rear wheels big block chevy.. Hell, you could do 2 kegs at once, lolPrairiepiss wrote:Jack your truck up. Pull a wheel off. And bolt it to the axle. Lolbellybuster wrote:was looking but can't find it. There was a video of a guy polishing a keg on a large metal lathe, the keg was spinning and he was using a huge buffer. That sucker was shinin within a minute. Now... if I can only find that giant metal lathe and chuck in the garage.....
My new still:
My old still
My controller:
My old still
My controller:
Re: Keg Polishing
Bolt those puppies on and do a few burnouts in a sand lot... Done...!!!Husker wrote:I was thinking the same thing. 420hp to the rear wheels big block chevy.. Hell, you could do 2 kegs at once, lolPrairiepiss wrote:Jack your truck up. Pull a wheel off. And bolt it to the axle. Lolbellybuster wrote:was looking but can't find it. There was a video of a guy polishing a keg on a large metal lathe, the keg was spinning and he was using a huge buffer. That sucker was shinin within a minute. Now... if I can only find that giant metal lathe and chuck in the garage.....
Re: Keg Polishing
Ha ha, GA, very funny.
I did start it last night despite my not wanting to.
Me denying my talent would be like Michelangelo NOT doing the Sistine chapel.
Or so GA can understand, it'd be like Dale Earnhardt Jr. not climbing into that ol' speed wagon ta shuck rubber on dat dem der asphalt.
- ga flatwoods
Re: Keg Polishing
Nascar sucks! Damn watching a bunch cars go round and round. Rigged like wrestling. Gran prix is real racing like in Europe not USA.
Ga Flatwoods
Ga Flatwoods
I am still kicking.
Ga Flatwoods
I am still kicking.
Ga Flatwoods
Re: Keg Polishing
I'm one of those guys, when I'm in the build, I make her shine... almost obsessive-compulsive, and the pics I post of my first build are gonna be shiny.
I know, after it goes to work, I'll probably never shine or polish up again, other than some basic wiping down. Copper, brass, bronze, all develop a nice patina with just a cotton cloth. I like to keep it between crusty green and brilliant new-penny.
But for a few weeks, it's a glorious thing to have shiny metal!
P.S. I come from an aviation background, and there are pilots who fly vintage airplanes who have the full-on obsessive-compulsive thing going on, and they keep their all-aluminum airplanes buffed to an insane shine. You need a welding helmet to get near them in sunlight. Empty gallon cans of nevr-dull litter their hangars. The work involved is immense. Got to respect that!
