enzymes?
enzymes?
Could I use the trub from my last AG to convert the starch in my next batch? Do the enzymes settle to the bottom. I'm just about to do a search but I figured I'd ask. Thanks
- MitchyBourbon
Re: enzymes?
You might find some wore out yeast but you aren't likely to find much in the way of enzymes.
I'm goin the distance...
Re: enzymes?
I thought that the enzymes just became dormant when the temperature drops below Mashing temp?
Re: enzymes?
You have it backwards... Enzymes die above the mash temperature... They will work down to room temperature at a progressively slower rate...copper sweat wrote:I thought that the enzymes just became dormant when the temperature drops below Mashing temp?
Re: enzymes?
dormant not denatured. what I'm asking is are the enzymes still alive after the fermentationrad14701 wrote:You have it backwards... Enzymes die above the mash temperature... They will work down to room temperature at a progressively slower rate...copper sweat wrote:I thought that the enzymes just became dormant when the temperature drops below Mashing temp?
- S-Cackalacky
Re: enzymes?
Enzymes aren't living organisms like yeast. They are proteins and are catalysts in the conversion of starch to sugar. These enzyme proteins are produced during the germination process and are used by us to convert grain starches to sugar. The enzymes are used up during the conversion. I guess there could possibly be some leftover enzymes if you add more than is needed for the conversion, but probably very little. Point is, enzymes aren't living organisms and don't reproduce themselves.
Re: enzymes?
I found what I was looking for on the interweb. Enzymes are limited by their saturation point. I always had the idea that they would continue to catalyze until they run out of carbohydrates or until they were denatured bye heat or Ph levels. my curiosity always gets the best of me.
- MitchyBourbon
Re: enzymes?
The saturation point of enzymes simply describes the limit at which a given enzyme speeds a given reaction.
Temperature and ph are not the only factors that can denature enzymes. Ethanol also dentures enzymes.
Re: enzymes?
That's interesting looks like I should do a lot more readingMitchyBourbon wrote:The saturation point of enzymes simply describes the limit at which a given enzyme speeds a given reaction.
- SoMo
Re: enzymes?
If everyone had your attitude this site would flow much better. Keep reading good luck.copper sweat wrote:That's interesting looks like I should do a lot more readingMitchyBourbon wrote:The saturation point of enzymes simply describes the limit at which a given enzyme speeds a given reaction.
