I am rather new to the scene but I have learned a bunch already. I have made about 6 or 7 good 10-gallon runs. I have a reflux still that sits on a half keg. Up to this point I have only used cracked corn to make whiskey. My process begins with cooking of the corn in water to "turn the starches into sugars". Wait for it to cool then add some enzymes and yeast.
My issue... I am only doing a 10 gallon run. However, I am not yielding much from a run. Well I did my very first run but haven't done as well since. My first run produced about 2.5 quarts. Every run after that has only made about half as much
I have tried to determine what variables could be controlling the yield but wanted to reach out to the guys that have done this before
I am pretty sure at this point the yeast is the variable I need to change. My first run consisted of some 48hr turbo yeast from a local HB shop when all the other runs consisted of some standard brew yeast. Only problem is that 48 hr turbo yeast is like $18-20 for one 10gallon mash. The standard brew yeast I have been using is like $10 for like 25 of the 10gallon mashes (by following instructions on the bag).
Questions:
1.) Is the 48hr turbo yeast the magic ingredient I need to stick with? (My time is worth a lot to me. I don't mind spending the money to make twice as much if that's what it will take.)
2.) Can I just add more of the standard brew yeast to yield more?
3.) Is there something else that could be controlling my yield amount that I am overlooking?
Thanks!
