Two stage proofing
Boda Getta
Two stage proofing
Post by Boda Getta »
I have several gallons of charred whiskey of several types on glass to age 8-12 months; they range from 125 to 135 proof. I have found that 186ish is right for me for bottle proof. I have read here where some proof down in a couple of stages. What is the advantages or disadvantages of this and what are the intervals and amount proofing for best results. In the past I have proofed down in one stage with good results but always looking for better.
BG
Re: Two stage proofing
I think you meant 86-ish, not 186-ish...
It really shouldn't matter whether you dilute down all in one go versus stepped dilution... It's going to take the same amount of water regardless... And I highly doubt it would make any difference to the flavor profile...
jarheadshiner
Post by jarheadshiner »
I'm betting that you're thinking of folks that do a solera type aging method at different proofs Boda...e.g., 125 in first barrel, then dropped to 115 for second barrel, 105 for third barrel. Those numbers are just examples.
I know that I go into information overload sometimes and things start running together. If this is not the case then just disregard my post :mrgreen:
Lead, follow, or get the **** out of the way!
bearriver
Post by bearriver »
I've never aged whiskey in a barrel for 10+ years. My lack of experience makes me wonder how much the angel's share plays a role in the decreasing proof from one barrel transition to the next over the years. :?:
Boda Getta
Yeah... 86ish proof, I've found that about right for me for UJ and SF. Have my first single malt at 125 proof aging, I will have to play around with it and see what my "sweet spot" for it will be. Also have some apple brandy at 100 proof aging, suspect I will go around 80 proof with it. My batch of SF w/rye is at 130 and I can't stay out of it; I have been "sampling" it with some regularity by proofing 2 ozs of 130 proof w/ 1 oz water and don't see how it could get much better. I thinking of leaving a gal at 130 and proof it down by the drink.
Bearriver:
Most of us use small charred kegs (I use 3 gal) for charring and most of us char in months, not years in these small kegs. The big guys use 53 gal barrels that can take 10 years. I char from 1 month to 3-4 depending on the no of cycles through that particular keg, then finish on glass.
BG
