Will Rum "age" in glass?
- Jersey
Hello all,
I do not have access to an oak barrel, and plan to store my rum in a sealed glass jug after steeping with some oak chips. Will long term storage in glass have any refining effect?
Regretting yesterday and worrying about tomorrow make for a very short ride....Carpe Diem!
Re: Will Rum "age" in glass?
Aging is aging... It requires time... The extraction of flavors and aromas can be duplicated fairly accurately in comparison to barrel aging by using chips, chunks, sticks, or spirals in a glass jar... We've had several discussion on the various methods of aging... Snoop around and then try a method that suits your needs...
- moosemilk
+1 with rads advice
I also don't seal, but use a natural cork stopper. Or just open it from time to time to let it breath.
I will say yes. Mine definately gets better as time goes on and I only store in glass bottles.
Hangover? I don't get no stinking hangover!
- Jersey
http://homedistiller.org/forum/viewtopi ... 15&t=55392
Answered my own question with a little patience..lesson learned.
Thanks!
Thanks!
- S-Cackalacky
Here are a couple of links that I found to be very helpful -
http://homedistiller.org/forum/viewtopi ... =4&t=38991
http://homedistiller.org/forum/viewtopi ... =4&t=50348
I've been using a variant of the nuclear method. I do 3 cycles with JD BBQ chips, strain into gallon jugs, and age for at least 2 months. The nuking seems to do a good job of extracting the goodness of the chips, but there's no shortcut for the benefit of aging, IMO.
I also plan to try T-Pee's method. His method would seem to put a handle on consistency once you get the method down. I'm looking forward to trying it.
- DAD300
Yes...
Many components don't rely on the wood. Esters and other compounds continue to form and change over time. Adding the proper amount of wood, agitating and aerating occasionally speed the good processes.
DSP-AR-20005
DSP-AR-20005
I've been debating what i'm going to age in.. while a barrel seems like a good idea or the best. I was going to go with a stainless container of some sort and then toss in chips or sticks. Just seems like to me int eh long run i can reuse it over and over and dont have to rechar a barrel or get a new one.
eh.. decisions decisions.
- Tokoroa_Shiner
One way to reuse a barrel over and over, is to drill the bung hole a bit bigger, and toss in some charred oak sticks.
The Rules By Which We Live By
Safety And Related Issues
New Distillers Reading Lounge
- bearriver
Be aware that when aging in a barrel the evaporation will occur quicker in a smaller barrel. I got a book somewhere here with a metric ton of data on the subject, but can't remember the specifics...bads197 wrote:I've been debating what i'm going to age in.. while a barrel seems like a good idea or the best. I was going to go with a stainless container of some sort and then toss in chips or sticks. Just seems like to me int eh long run i can reuse it over and over and dont have to rechar a barrel or get a new one.
To summarize, if you age in a barrel you can expect substantial losses due to evaporation. The liquor gods demand their tribute.
I was given a gallon barrel as a gift and aged some fifth gen UJ in it. I lost nearly fifty percent to evaporation. The remaining liquor is still the best spirit I've made.
Two different things going on.
Evapouration of the angels share - can't occur in sealed containers unless there is some form of vapour path, such as a wood or cork top on a glass container.
Flavour modification - hence use of wood chips or blocks in jars of spirits.
Note there are some reports of commercial distillers using accelerated aging with smaller barrels, oak staves and other methods. If you can't tell the difference between a real 20 year old whisky and an accelerated 20 year old whisky, then apparently it is ok to label it as 20 year old!!!
- Teddysad
I am so pleased this does not apply to girlfriendsmyles wrote: If you can't tell the difference between a real 20 year old whisky and an accelerated 20 year old whisky, then apparently it is ok to label it as 20 year old!!!
You can lead a horse to drink, but you cant make it water!
You can lead a horticulture but can you teach a prototype?
Proverbs 31:6-7
Proverbs 31:6-7
Yes it will get better aged and oaked in Glass, it will get even better aged in a barrel.
- MooseKnuckle
Curious if this works well with fully corked wine bottles (corked with a corker) or if simple tapered cork pressed on by hand is the only way for it to share with the angels?
