Hi, I'm cleaning out a used anheuser Busch 15.5 gal beer keg (humanely purchased) and this little purple gasket is inside, do I new to remove this and if so how? It's pretty stuck in there, im sure I could pry it out with a little elbow grease but I'm afraid of the glue that may be left.
Thanks all
Remove gasket inside keg?
- Snackson
Re: Remove gasket inside keg?
Did you remove the lock ring and keg spear? Or are you talking about the gasket on the spear? Could you post a picture?
http://i.imgur.com/ExzUGSk.jpg
It's the purple guy, it's firmly attached to the keg. Sorry I forgot to add the picture on the original post
Many members here will not click on links to images hosted on external hosting sites... Can you upload the picture here...???
I would remove it and clean it up with some scotch Brite or sand paper, I wouldn't want that coming in contact with my vapor.
- bearriver
+1rad14701 wrote:Many members here will not click on links to images hosted on external hosting sites... Can you upload the picture here...???
- Danespirit
As you managed to remove the spear already, there should be no lockingring down there.
So just pry it out with a screwdriver.
It's important you get it all out, so it has to come out of the top, instead of just hammering it into the keg.
hi all, just to update should anyone care. turns out the gasket was stuck on by gross junk. Once I soaked the keg in PBW the gasket popped right out.
