Best Yeast?
Best Yeast?
Does anyone have any suggestions for what kind of yeast to use. Only thing I've ever used was alcotech 48 hour turbo yeast but I've heard it wasn't the best for corn liquor or sweetfeed shine.
- jedneck
Re: Best Yeast?
Bakers yeast here. Dirt damn cheap and it works. That or an ale yeast.
big help
Dunder
big help
Dunder
- corene1
- HD Distilling Goddess
Re: Best Yeast?
A lot of that depends on what you are fermenting and the temps you have to work with. For whiskies I would say most here use bakers yeast . I use Red Star and keep it at around 80 to 84 degrees. Many others use Safale us-05 for their whiskies when fermenting at lower temps, but there are many more yeasts out there. These are just the 2 that I have used personally.
- Hillbilly Popstar
Re: Best Yeast?
I like the EC1118 cause it finishes dry and I don't need to keep my fermenter warm.
Re: Best Yeast?
Baker's yeast? Like Walmart bought redstar packs? If it works well that seems like a good... Cheap... plan.
- HDNB
Re: Best Yeast?
i like fleishman's bakers yeast. ferment a t room temp, no heat added around 68-70 sitting on concrete. most average SG's finish and clear in 6 days...ready to strip. i have been getting a pound ($8) to last about a year. but that's because i ain't never made no whiskey, and i ain't gonna make no whiskey either.
i really want to try US05, but you think i can remember to stop and buy some...
now i drink for evil.
- Hillbilly Popstar
Re: Best Yeast?
Well this is promising seeing as how I just pitched some bakers yeast (Fleishman's) for the first time and was worried I'd have to keep it warm.HDNB wrote:i like fleishman's bakers yeast. ferment a t room temp, no heat added around 68-70 sitting on concrete. most average SG's finish and clear in 6 days...ready to strip. i have been getting a pound ($8) to last about a year. but that's because i ain't never made no whiskey, and i ain't gonna make no whiskey either.
- HDNB
Re: Best Yeast?
thats a 200L barrel, i do put the 6 gallon ones up on a table. on concrete the small buckets take a couple more days.
i have one of those radiant tube gas heaters about 15' away from the barrel, don't know how much that helps.
- joeyfla
Re: Best Yeast?
I'm using Fleishman's bread yeast for the Sweet Feed. Mine ferments in an 8 gal stainless steel milk can in the house which stays at 75 degrees F. Year round.
Re: Best Yeast?
Sam's Club... 2 - 1 pound vacuum bricks for ~$5.00... A lot cheaper than the sachets in the grocery stove...Fishy60 wrote:Baker's yeast? Like Walmart bought redstar packs? If it works well that seems like a good... Cheap... plan.
Re: Best Yeast?
I bought two of the four ounce jars of flieshmanns yeast.
- biggybigz
Re: Best Yeast?
I'm a huge fan of US-05. Ferments very clean. After airing out, I'm not sure the fores even smell that bad. Very little esters. It's pricy but to me it's worth every penny.
Re: Best Yeast?
I like Kroger's store brand bakers...
Deo Vendice
Deo Vendice
Re: Best Yeast?
how do these bakers yeasts go with basic sugar and water ?
room temp here lately is between 28c and 38c,colder at night [about 24c]
but will be getting colder soon.
i think i'll have to run a brew off until i get this grain mix sorted.
ausguy.
ausguy.
Re: Best Yeast?
Bakers yeast is a really good base point, if you know how that works at your heat we can work from there. Best is really only good if you know what you want and where you are. My best yest might not work for what you need. Your best might not be what I want in my environment.
It's all about heet. What Temps are you fermenting at? Figure that out and we go from there.
- T-Pee
Re: Best Yeast?
Best yeast?
Imo baker's for grain or sugar ferments at 80*-90*, EC-1118 for fruit washes at 60*-70*.
tp
tp
Handy Links:
The Rules We Live By
GA Flatwoods sez
Handy Links:
GA Flatwoods sez
Re: Best Yeast?
80f = 26.5c to 90f = 32c which is the temp range up here at the moment.T-Pee wrote:Best yeast?
tp
gotta go shopping tomorrow [120km round trip] so ill pick some up then.
Re: Best Yeast?
Q.) in a 25ltr drum of sugar base,how much bakers yeast would you use ? teaspoon ? 2 teaspoons ? more ?
ausguy
ausguy
Re: Best Yeast?
I use 1 packet (sachet) for a 5 gallon ferment. Sometimes, I buy 3 packets at a time (because that's the way you get them at the grocery store). Then, I split them between two 5 gallon ferments (1-1/2 sachet each).ausguy wrote:Q.) in a 25ltr drum of sugar base,how much bakers yeast would you use ? teaspoon ? 2 teaspoons ? more ?
Yeast will reproduce (often called "budding") until the required cell count is available to transition into the latent ferment phase. It is good because the young, freshly "budded" cells are healthy and hungry. And they'll smell very bready like fresh bread dough.
To promote healthy budding of the yeast, you need proper areation in the initial wort, as the reproducing phase is aerobic. But when the yeast transition into active fermentation, the process becomes anaerobic (without oxygen) and the yeast expire CO2.
Summarizing, 1 to 2 teaspoons per 25 liter wash should be good. And remember, baker's yeast likes it warm (80 to 85*F).
And don't forget to rehydrate your dry yeast prior to pitching. Use warm tap water only, not a sugar solution. You can rupture the fragile cell walls due to osmotic pressure if you use a sugar solution to rehydrate.
Re: Best Yeast?
How much you use is up to you... The yeast colony will remain in aerobic phase as long as possible to build the cell count but most here tend to over-pitch to reduce lag time... I pitch a lot more yeast into the same size wash, but that's just me... I've been known to pitch 1 tbsp (3 tsp) per gallon (4 - 5 liters) of wash... A good rule of thumb would be a single sachet or ~2.5 tsp for a 25 liter wash... Maintaining a constant temperature and providing enough nutrients is more important than the amount of yeast pitched...ausguy wrote:Q.) in a 25ltr drum of sugar base,how much bakers yeast would you use ? teaspoon ? 2 teaspoons ? more ?
ausguy
- thecroweater
Re: Best Yeast?
You are not going to find the brands these guys are talking aboutausguy wrote:80f = 26.5c to 90f = 32c which is the temp range up here at the moment.T-Pee wrote:Best yeast?
Imo baker's for grain or sugar ferments at 80*-90*, EC-1118 for fruit washes at 60*-70*.tp
Use Lowens that most aussies do and 50g is ample for 25 to 30 ltrs , not keen on that tandaco sachet yeast crap myself but you can get the 280g cans of Lowens red in any supermarket of grocery shop for around $4. This yeast is actually bred on a strata of molasses and so is perfectly suited to any sugar wash or sugar head mash, like I said elsewhere for all grain it will work but there are better options and for fruit DO NOT USE IT, it doesn't play nice with fruit flavours
Re: Best Yeast?
lowans red can is what i got
couldnt find any corn meal though
- thecroweater
Re: Best Yeast?
Stock feed shop and get cracked or rolled maize (not the rolled shit they put molasses in unless you want to make a sweetfeed deal) or in pet shops (costs way more) and get the crushed corn chook food. Generally you can by the meal in supermarkets but its not so cheap.ausguy wrote:lowans red can is what i got![]()
Re: Best Yeast?
thanks mate,i'll take a look next week.
Re: Best Yeast?
couldnt find crushed corn,corn meal or flaked maze.[none in emerald,qld]
so i ran off a couple drums of sugar with bakers yeast and added nutrients.....
very poor output.yield was much lower,but still @ 86%alc/vol.
anyhow....
like with my target shooting,ill keep trying get the scores up..
anyhow....
- thecroweater
Re: Best Yeast?
How far is Capella, Obrian trading stockfeed and fodder supplements If that doesn't work out go see CQ Ag services , they are stockist of Laucke mills products so you caould order Laucke's cracked or rolled corn through themausguy wrote:couldnt find crushed corn,corn meal or flaked maze.[none in emerald,qld]![]()
anyhow....like with my target shooting,ill keep trying get the scores up..
Re: Best Yeast?
capella is over an hr away.
thanks for the tip on ag services.
- cuginosgrizzo
Re: Best Yeast?
Well actually Capella (Alfa Aurigae) is much further away than that. It's about 42,5 light years from here. Might be closer from your place
Re: Best Yeast?
geek out much ?cuginosgrizzo wrote:Well actually Capella (Alfa Aurigae) is much further away than that. It's about 42,5 light years from here. Might be closer from your place
