Convert fan controller for element?
I have a fan speed controller left over from my indoor gardening days. I was wondering if anyone knows if I can use it or convert it for use with an internal heating element. I read somewhere about people converting other controllers by adding a heat sink. Here is a link to the controller I would be using: http://controlwizardproducts.com/prodde ... Controller" onclick="window.open(this.href);return false;" rel="nofollow Obviously I would be running on a 120v outlet and not 240v.
Re: Convert fan controller for element?
How big is your internal heating element?
The speed controller might work, provided your heat element is 1.5kW or less.
- dieselduo
Take the back off and add a heat sinkcat herder wrote:I have a fan speed controller left over from my indoor gardening days. I was wondering if anyone knows if I can use it or convert it for use with an internal heating element. I read somewhere about people converting other controllers by adding a heat sink. Here is a link to the controller I would be using: http://controlwizardproducts.com/prodde ... Controller" onclick="window.open(this.href);return false;" rel="nofollow Obviously I would be running on a 120v outlet and not 240v.
here's a link to a hotrod speed controller
http://homedistiller.org/forum/viewtopi ... 15&t=32906
I was going to use a 4500w element, but on a 120v circuit so it would be 2250w if I understand things correctly. That probably means I have to upgrade the wiring on the controller, right? Also my guess is that this thing would have to run on at least a 20amp circuit. 2250w is probably too much for a 15 amp circuit. Maybe it would be better to find an element that runs at 3000 w on a 240v circuit and run it at 1500w on a 120v. Thoughts? 15 amp circuits are what I have most readily available.still_stirrin wrote:How big is your internal heating element?
- ShineonCrazyDiamond
Nope. When you put it on 120, you get a 1/4 of the watts. So that 3000w becomes 750w.cat herder wrote:I was going to use a 4500w element, but on a 120v circuit so it would be 2250w if I understand things correctly. That probably means I have to upgrade the wiring on the controller, right? Also my guess is that this thing would have to run on at least a 20amp circuit. 2250w is probably too much for a 15 amp circuit. Maybe it would be better to find an element that runs at 3000 w on a 240v circuit and run it at 1500w on a 120v. Thoughts? 15 amp circuits are what I have most readily available.still_stirrin wrote:How big is your internal heating element?
Shine on you crazy diamond."
4500 / 4 = 1125W
3000 / 4 = 750W
Either 240V element would work...
3000 / 4 = 750W
So all I need to do is add a heat sink to the controller, and wire the element to a power cord, right?
- bluefish_dist
If that doesn't work, search for super simple controller. Cheap, easy to wire and if you add a volt/amp meter for ~$10 you have good control. Just make sure to add a fan to help keep it cool. Heat is your enemy.
Formerly
Dsp-CO-20051
Dsp-CO-20051
- bluefish_dist
Formerly
Dsp-CO-20051
Dsp-CO-20051
Wouldn't it just be easier to buy a $20 SCR and know it works?
Using Google Search
Using Google Search
- cranky
+1Hound Dog wrote:Wouldn't it just be easier to buy a $20 SCR and know it works?
Here is a link to some of the best SCR info
http://homedistiller.org/forum/viewtopi ... =2&t=43456
and although there are lots of build threads out there, here is how I did my own SSR controller
http://homedistiller.org/forum/viewtopi ... 85&t=50385
I think either option is better and neither is very pricey.
This seems a good option to me also. I have to learn a bit about electronics to learn how to connect one to power and to the element, but it seems as though you just attach the wires to the right terminals and go. Unless I'm mistaken it's pretty simple.cranky wrote:+1Hound Dog wrote:Wouldn't it just be easier to buy a $20 SCR and know it works?
http://homedistiller.org/forum/viewtopi ... =2&t=43456" onclick="window.open(this.href);return false;" rel="nofollow
http://homedistiller.org/forum/viewtopi ... 85&t=50385" onclick="window.open(this.href);return false;" rel="nofollow
- cranky
With the SCR that's exactly what you do. With the SSR you have to add a potentiometer and a cooling fan.
DIY Controller Kit: http://stilldragon.com/index.php/diy-sm ... oller.html" onclick="window.open(this.href);return false;" rel="nofollow
Instructions: https://www.stilldragon.org/uploads/man ... 131020.pdf" onclick="window.open(this.href);return false;" rel="nofollow
