My electrical prowess once again is continual evading me. Sorry for the elementary question.
I have a 110v dimmer switch I want to use to control the speed of my 12v cooling fan. Do I wire that switch in between the power source and the receptical that my wall wart plugs into inside my controller or between the wall wart and fan.
110v Dimmer for 12v fan
- BoisBlancBoy
Re: 110v Dimmer for 12v fan
You must wire the dimmer switch on the 120V side of the circuit, either between the mains and the outlet or between the outlet and the 12V transformer...BoisBlancBoy wrote:My electrical prowess once again is continual evading me. Sorry for the elementary question.
- BoisBlancBoy
Thanks Rad!
See your redundant (other) thread regarding this same subject.
Yeah, that wall wart probably won't be too happy being controlled by a dimmer... One thing that can work with lower amperages is a simple potentiometer... For example, a 1W rated 10K Ohm potentiometer in the 12V circuit might do the trick...still_stirrin wrote:See your redundant (other) thread regarding this same subject.
