The problem is this hot plate makes a very loud and very angry humming/buzzing sound any time the current is modulated. I’ve seen this hot plate mentioned on several other threads and never seen any complaints about it, it is a nice unit.
I’ve tried a 15A router controller I have that has an OFF/FULL/VARIABLE toggle and it only hums when switched to variable, even if the dial is turned all the way up. Ok, I know you’re not suppose to use these things anyway so on to option #2.
Lucky me, I happen to have a 2000W Lutron dimmer with a big ol’ heat sync leftover from the days of halogen and PAR lighting. I wired that up to a GFCI duplex in a 3-gang junction box and the hotplate does the same exact thing!
Both devices seem to work fine with my wife’s hair dryer, fortunately.
What do you guys think is going on? Is this normal? I don’t want to invest more into this setup since I’m going to be using 240W internal elements on my own still but I don’t want to wait until it is complete to run these low wines either. 1300W isn’t massively overpowered so it might be fine to just use it full-speed or I could probably pick up a 750W el cheapo if really necessary but I’d really like to try and get this figured out since this alembic is so attractive and I’ll probably still use it from time to time on smaller spirit runs since I’m building my still on a 15-gallon boiler.
Thanks y’all.
