"Will a slant plate VM Design Work?"
Here is a quick draw-up of a 2x2x1 Slant Plate VM head... It has two variations of plate angle and also two variations of plate depth, 50% and 33% (.25" past halfway for 2")... I have used this site for the volume calculations for various column sizes... For this application L=1, R=column radius, r=0, y=any arbitrary value... I just click Compute Volume and then goto step 4 and generate a table of incremental values... Every column size needs its own chart...
I actually like this idea better because it could be a bit tricky trying to get the elbow inside the Tee without a shoehorn or butchery... This issue came to mind while drafting the previous examples...
Okay, minime, off to your mad lab to do some testing...
This topic has 101 more replies
Register Login
