I am getting ready to build a pot still column for whiskey. I have a 18" piece of 2" copper an was going to use a 2" to 1/2 " reducer coming straight of the top of the column.Then down to a coil.
Will this work or will it be way to slow?
beer keg
propane heat.
Thanks guys.
Will this work or is it to small?
Moonshine the flavor of the South.
Re: Will this work or is it to small?
pro65 wrote:I am getting ready to build a pot still column for whiskey. I have a 18" piece of 2" copper an was going to use a 2" to 1/2 " reducer coming straight of the top of the column.Then down to a coil.
beer keg
propane heat.
Thanks guys.
I went from 2" to 3/4. A 6 gallon wash takes 2 1/2 hours to strip. I am a noob so I cant say if that is slow or not. Seems slow to me.
This is so much fun it ought to be illegal..wait..never mind.
51" LM and a 24" Pot still with 62" Liebig with turbulator and spiral coolant swirler thingy. Both running on an unmodified keg with Tri-clover clamp attachment.
@pro65...
Using 1/2" copper should be just fine as long as you have enough of it to cool all of the distillate... Of course 5/8 or 3/4 would provide more surface area but not substantially more...
@FeralPig...
2.5 hours for 6 gallons doesn't sound slow to me...
@FeralPig...
![Image](http://i185.photobucket.com/albums/x100/pro65/potcolumn002.jpg)
This is what I am talking about, my column will go from 2" to a 1/2" take-off and I will add a peice of 1/2" tubing to go down to the worm.
I would put in a 2" 90 degree turn at the top of the 2" column, there would be less stress ond less chance of acidental bending on the 1/2" tubing.
Yep, a 2" elbow would make life so much easier. Sorta like my still except that my lyne arm is tapered from 2" to 3/8".
blanik
blanik
Cumudgeon and loving it.
