temperature drop couple of times during middle of run
Hi All,
Running my reflux still in a different location (400km inland, 900ft higher above sea level than where i was previously running it) and everything was going well, I was collecting at 91% and water flow was ideal until about 2 hours in the temp dropped from 78.4 deg C to around 61 deg C, it went back up over a time period of about 2 mins but this was the first time something like this has happened.
has anyone experienced this? if so do they know the cause of it?
Cheers;
SMiTH
Cheers;
SMiTH
Re: temperature drop couple of times during middle of run
I would bet that you heat with electrisity and don't have a proper controller, so the element cicles.
Is that the case?
Joe
Is that the case?
Joe
I am heating with electricity yes, what do you mean by controller but? I'm not running it any different now than I was a month ago and I wasn't experiencing this previously.
A picture of the rig is always helpful....
Three sheets to the wind!
My stuff
My stuff
61 Deg C looks like the temp of the reflux straight off the condenser. Is it possible for some reflux to occasionally dribble onto the thermometer probe?
Heres a couple of photos, unsure if they will help?
Ah ok, you probably had a water pressure increase and that would have put your rig into total reflux.
My stuff
My stuff
I'm still with the idea that the thermostat didn't work well.
That still has a water jacket which does the reflux but it runs down the mini column and doesn't touch the thermometer.
BTW: You have three hoses, two are cooling water in and out.
If the third is what I think try to get rid of it and use a copper tube.
Joe
Joe
If that boiler is anything like my old one (which is a fair assumption because the head is almost identical), then it doesn't have a thermostat.
My stuff
My stuff
Kiwi is right, no thermostat on the boiler, and I am looking into getting some copper tubing to replace the output hose, cheers Joe
Hmm Smith, if you would live in EC I would say your electric energy went for a moment
, but...
At the moment I have no explanation other than that your thermometer got drunk.
Good that you change the take off.
Wow...
All that high proof alcohol exiting through a coupler constructed from plastic and rubber, then into the hose... Definitely go with either copper or stainless... An easy fix...
Voltage drop (brown out) of even 10% will cause that. Or a heating element going bad or shorting out. How long did it take to recover? Is your water system on a well? A sudden surge of water pressure could also be the culprit.
I have the same unit as you and have had a similar thing happen. I found that the temerature will fluctuate if I have the cooling water flow set too high.
didnt take long to recover, I'd say less than a minute. Water flow was normal, ran it back at the usual place yesterday and this didnt happen at all....
