temperature drop couple of times during middle of run
SMiTH
Post by SMiTH »
Hi All,
Running my reflux still in a different location (400km inland, 900ft higher above sea level than where i was previously running it) and everything was going well, I was collecting at 91% and water flow was ideal until about 2 hours in the temp dropped from 78.4 deg C to around 61 deg C, it went back up over a time period of about 2 mins but this was the first time something like this has happened.
has anyone experienced this? if so do they know the cause of it?
Cheers;
SMiTH
rednose
Re: temperature drop couple of times during middle of run
Post by rednose »
I would bet that you heat with electrisity and don't have a proper controller, so the element cicles.
Is that the case?
Joe
SMiTH
Post by SMiTH »
I am heating with electricity yes, what do you mean by controller but? I'm not running it any different now than I was a month ago and I wasn't experiencing this previously.
kiwistiller
Post by kiwistiller »
A picture of the rig is always helpful....
Three sheets to the wind!
My stuff
Ayay
Post by Ayay »
61 Deg C looks like the temp of the reflux straight off the condenser. Is it possible for some reflux to occasionally dribble onto the thermometer probe?
SMiTH
Post by SMiTH »
Heres a couple of photos, unsure if they will help?
kiwistiller
Ah ok, you probably had a water pressure increase and that would have put your rig into total reflux.
My stuff
rednose
Post by rednose »
I'm still with the idea that the thermostat didn't work well.
That still has a water jacket which does the reflux but it runs down the mini column and doesn't touch the thermometer.
BTW: You have three hoses, two are cooling water in and out.
If the third is what I think try to get rid of it and use a copper tube. :wink:
Joe
kiwistiller
If that boiler is anything like my old one (which is a fair assumption because the head is almost identical), then it doesn't have a thermostat.
My stuff
SMiTH
Post by SMiTH »
Kiwi is right, no thermostat on the boiler, and I am looking into getting some copper tubing to replace the output hose, cheers Joe :D
rednose
Post by rednose »
Hmm Smith, if you would live in EC I would say your electric energy went for a moment :lol: , but...
At the moment I have no explanation other than that your thermometer got drunk. :mrgreen:
Good that you change the take off. :wink:
Wow... :shock: All that high proof alcohol exiting through a coupler constructed from plastic and rubber, then into the hose... Definitely go with either copper or stainless... An easy fix...
diesel4ever
Post by diesel4ever »
Voltage drop (brown out) of even 10% will cause that. Or a heating element going bad or shorting out. How long did it take to recover? Is your water system on a well? A sudden surge of water pressure could also be the culprit.
mackay australia
Post by mackay australia »
I have the same unit as you and have had a similar thing happen. I found that the temerature will fluctuate if I have the cooling water flow set too high.
SMiTH
Post by SMiTH »
didnt take long to recover, I'd say less than a minute. Water flow was normal, ran it back at the usual place yesterday and this didnt happen at all....
