So,
While I am hoping rad or PP will see this and get to your question Frost, I would like to just make a quick list of important points from page 1 (for any one reading along) so that we can go on to discuss page 2, the actual distillation part.
Just in general terms...
Liquids
1) A liquid has forces that help to keep it together, a big one is intermolecular attraction: the amount of how much the molecules want to "stick together" (hydrogen bonding can play a huge part in this)
2) Molecules are in motion in the liquid (kinetics) and the faster a molecule is moving the more likely it can escape .
3) When a molecule escapes it becomes what we call a gas.
4) increased heat means the molecules move faster are are even more likely to escape.
5) vapor pressure is a measure of the pressure exerted by the molecules escaping the liquid, so think of it as a measure of how easily the molecules escape.
6) vapor pressure is approx = to volatility
7) when the vapor pressure equals the pressure exerted by atmospheric pressure ( ~14.7 psi) the liquid will boil.
8.) So boiling point is the temp at which vapor pressure equals atmospheric pressure (see # 4)
9) Finally increased vapor pressure means increased volatility and as a result a DECREASED boiling point.
Mixtures and Raoults law
in general terms (for ideal mixture)...
1) In ideal mixture of liquids each individual component will behave the way it does as a pure substance (same amount of intermolecular attraction)
2) When we mix 2 substances (say A and B) with different boiling points (BP) the new liquid will have a new boiling point (BP) that is somewhere between the lowest (say B) and the highest (A).
3) What determines where that BP lies exactly depends on the ratio of how much of A we have versus how much of B we have (like a fraction).
4) If we have way more of B than A then the BP will still be between the two but will be way closer to the BP of B. If its way more of A then its still in the middle but way closer to the BP of A.
This makes sense with what we see as distillers at a the beginning of a run when we are taking off mostly ethanol isnt the temp really close to the BP of ethanol (BP ~78C). And later at the end of the run isnt the BP going up and up as we have more and more water (BP ~100C)!
7) Here is the biggie which I will repeat because its really important. Just because we mixed them (in an ideal mixture) we did not change thier individual physical properties. So when we boil a mixture of A and B, and B is more volatile (lower boiling point), then both will escape the liquid (not just B). BUT more of B escapes than A exactly because B is more volatile. We are separating them based on thier vapor pressure! NOT because one is lighter than the other. (water at 18 amu weighs less than ethanol 46 amu but ethanol is more volatile)
8.) A phase diagram does an excellent job of showing you visually what we are talking about in #7
Rad has one here in the forums I have seen it and there is an interactive ones on the parent site here
http://homedistiller.org/theory/refluxdesign/steps having read this I encourage you to play with it and think about what we are talkng about.
Ps If i misstated stuff here pls correct me I dont want to give out false info
ps ps--on #7 please dont go down the VM road that last step is a 2nd (and ingenious) separation based on a
different physical property than vapor pressure, namely the density of a gas.
