Question about gas for propane torch
Kentuckyman
Post by Kentuckyman »
Before I run out and spend money on more propane, I happen to have several cylinders of gas in the shorter fat squat bottles which I have for a Coleman lantern and a Coleman heater. I assume the only difference is the shape of the bottle? Not knowing a lot about soldering with a propane torch, I figured the safest bet is to ask those who know. I only see this shape in stores camping department, where plumbing departments only seem to have the traditional longer thinner cylinders. Am I good to go with the squat bottles on a torch? Nothing in the torch instructions mentions this.
Thanks in advance,
Russellc
Da Yooper
Re: Question about gas for propane torch
Post by Da Yooper »
Yes good to go :thumbup:
Fail to plan == plan to fail
drinkingdog
Post by drinkingdog »
They have the same propane gas as the regular longer bottles. You can get the special map gas cylinders that burn a little hotter. You're good to go.
My Grandpa used to say. Don't argue with an idiot, because he will just drag you down to his level then beat you with experience.
He also used to say. I didn't say it was your fault. I just said that I was blaming you.
DD
Kentuckyman
Thanks guys, time for a little chore out in the garage....maybe basement...little chilly today!!
Kentuckyman
Kentuckyman
WOW! Iwent to the grocery and when I came back, my cat had built a 3ft Liebig condenser!
How do I post pics here? I dont see a "manage attachments" tab? Looked at "control panel" as per forum instructions, but still no manage attachments that I can see. Is there a required number of posts before one can post pics, or am I looking right past it on control panel?
Kentuckyman
Kentuckyman wrote:How do I post pics here? I dont see a "manage attachments" tab?
Look below your post compose window, below the first Submit button... And posting is covered HERE... The part about attaching from within a forum post isn't there because it should be obvious when posting...
Kentuckyman
Yes, I have read that section. Below my submit button, there is no manage attachments tab. Perhaps I should try a different browser than google chrome?
Below my submit button is only an Options with boxes to check: "Disable BBC Code"
"Disable smilies"
"Do not automatically parse URLs"
"Attach a signature"
Notify me when a reply is posted"
Then it shows the posts again...
I belong to many forums and am familiar with the usual procedure for doing so...but, like I said already, There is no "manage attachments" Anyone else using Chrome? Maybe I should try FF or IE?
Russellc
Kentuckyman
It must be some anomaly. On the Artisan Distiller forum there is a manage attachments button by the "Options" It just does not appear for me on this forum!
Kentuckyman
OlympicMtDoo
Post by OlympicMtDoo »
Something is haywire, I'm looking at in right now and on mine just to the right of options it has a tab for Upload Attachments, you don't ?
bellybuster
Post by bellybuster »
tab right beside the options tab for upload of attachment.
This is what I get using the subsilver2 theme... I just uploaded the image while composing this post...
Kentuckyman
OlympicMtDoo wrote:Something is haywire, I'm looking at in right now and on mine just to the right of options it has a tab for Upload Attachments, you don't ?
No I dont. It looks just like the included post below, minus that tab! Only options.
Kentuckyman
Kentuckyman
Just tried it with firefox, still no tab beside options with this browser either. I will try IE next. Only the "options" tab shows...
Kentuckyman
