i ate the whole thang...!
i jus thought i were confused b4...
Harbor freights speed controller works on my 1500 watt pot still.cwood wrote:What about a Router Speed Controller....? I believe they are just HD rheostats, not the preferred variac.However, because they are designed to regulates the speed of a router motor, probably up to 3 HP at say 10-15 amps, wouldn't that do just as well...? Easy to plug into wall, and plug heating element into Speed controller....??? Not too pricey either..... Anybody ever done that??? Feed back............??
Thanks,
CW
That would depend totally on the specifications provided by the manufacturer... While most controllers are constructed with components that are rated for higher voltages than they are intended to be used with some of the components may not be able to handle the prolonged exposure to higher voltages... It should also be noted that some components may be selected for only a specific voltage range... For example, some controllers use potentiometers and ancillary components for optimal 120V or 240V mains power and won't work as effectively if a different power rating is supplied... And some can handle a wide range of mains voltage inputs without issues... Always stay within the rated mains voltage recommendations...studlyisme wrote:On one of the home still sites I see they sell 20A 120v router controllers to power thier 1500w elements so im guessing they work just fine? I see them on amazon for $30- My question is I see someone said they were going to run a 220v element with thiers- is that fine to do? I have a 15g keg and would love to go 220 at some point in time but just not possible untill I rewire the garage.. Ill be running dual elements (one strait and one controlled) was going to go with 2 of the 1500w 120v elements but can I put the 120v controller on a 220 element and it will just output less heat? like 1500w instead of 5500w? That way when I upgrade to 220 alls Id have to do is get a new controller?
Depends on what your asking here. Are you talking about using the controller on 120 it 240?studlyisme wrote:On one of the home still sites I see they sell 20A 120v router controllers to power thier 1500w elements so im guessing they work just fine? I see them on amazon for $30- My question is I see someone said they were going to run a 220v element with thiers- is that fine to do? I have a 15g keg and would love to go 220 at some point in time but just not possible untill I rewire the garage.. Ill be running dual elements (one strait and one controlled) was going to go with 2 of the 1500w 120v elements but can I put the 120v controller on a 220 element and it will just output less heat? like 1500w instead of 5500w? That way when I upgrade to 220 alls Id have to do is get a new controller?
i have a PSR the same and use a PC heat sink i run a 2400w 240v 50L kegandrewgwu wrote: I also noticed the schematic in the PSR-25 specs says a filter is required for this unit, but have noted in previous discussion on this forum that it is not for our purposes.
As I understand it I will run the ground wire to the relay where it attaches to the sink (with a ground coming off for the pot) and then on through to the stainless keg. If I chose to put in an appropriately rated on/off switch then it would also need to be connected to the ground. I will wire the pot on connection 3 and 4 of the PSR. One line will run all the way through. The other will be connected between post one and two. The "neutral" and "load" connections
This all seems pretty straight forward to me, but I wanted to make sure I wasn't missing anything. Does anyone see anything wrong with my parts list before I purchase these things or anything I need to add?
Jay_G wrote:Having read a bit of this thread and thoroughly confusung myself i found this 3200w controller for $12.40 AUD and have now got one on the way to use on my 30L 2100w Urn
Here
All of the models I checked appear to be well constructed... The addition of a CPU cooling fan would definitely increase reliability...tomgndallas wrote:Jay G,
Any further reviews on this product? It was coming from Hong Kong so I am curious about its reliability after sustained use. Looks robust enough with that heat sink, but looks can be deceiving. As a seasoned veteran of traveling in China and buying from the copymarkets, you never know what you are going to get or how long till the wheels fall off!
Tom G
I have used it once now for about 6 hours straight, worked a treat, although i think i will be putting a fan on the heatsink as it got quite hot, almost untouchable, (it was a close to 30 degree c day) i also need to fit it to a container, as it has bare tracks on the pcb on the bottom so it is a bit of an electrocution risk.tomgndallas wrote:Jay_G wrote:Having read a bit of this thread and thoroughly confusung myself i found this 3200w controller for $12.40 AUD and have now got one on the way to use on my 30L 2100w Urn
Here
Jay G,
Tom G
Did you drop from a 500K to a 250K potentiometer...???duracell wrote:I already have built a 240v controller using odessits diagram, and now I am trying to build a 120v version but am having some problems. I am using the same components as the 220v version, but the best I can get it to do is go from off, to half power, then full power with no inbetween. Increasing the value of the 10k resistor makes the circuit go on instead of off which is counter intuitive to me. Any ideas?
Yes this is the phase angle controller. I have tried both the 500k and 250k pot but there is no linear control, just off, mid and high. Furthermore it's not stable at these settings it will wander between these 3 modes by itself, maybe since you barely have to turn the pot to move between these 3 settings.rad14701 wrote: Did you drop from a 500K to a 250K potentiometer...???
Also, I'm assumingyou are referring to the phase angle rather than 555 PWM based controller...
