I new at this and Ive been having trouble with my fermentation. I'm on my fifth and not very successful batch. All 5 where sugar wash. At first i thought my problem was not enough heat because I'm doing it in my basement (its 18C down there), so i got a heating pad witch has helped a bit. Then i figured i was using to much sugar, so i lowered my sugar content with no luck. So now I'm asking for help.
Here's what Ive done with the current batch. (all 5 recipes batches where different)I got the current recipe from The Compleat Distiller" except i changed Fermaid for Dap.
Recipe for demijohn 54L:
10 Kg sugar (diluted with hot water)
45 gr of DAP
added 18gr on second day and 18 more on third day
7 gr of calcium carbonate
I filled the rest with cold water splashing it to get plenty of air in there. (city water)
Pitched 3 packet of EC-1118 (5 gr each)hydrated as per packet instructions.
My starting specific gravities was 1.070
24 hour later the wash was pretty warm but the temperature came back down after about 48 hours.
Ive wrapped the demijohn basket with insulation and put a heating pad with a thermostat inside the basket. Ive set the temperature so it stays at 25C ( the temperature in basement is between 16-18C.
For the first two 3 days i couldn't take a SG reading because there where to many bubbles in the wash, they would push the hydrometer up.
After 4 days the SG was about 1.050.
After 7 days the fermentation was going really slow (1 bubble through the airlock every 5 seconds or so) SG was 1.045
So on day 8 i added 2 more packets of yeast, that didn't do much so on day 9 i added some dap (about 2 teaspoons) it started to ferment a little more.
Now its been 2 weeks and its slowing down again, my SG is 1.036.
So what am i doing wrong? Any ideas?
I have no idea what my initial PH was, ive ordered a PH kit for the next batch.
