Blackstrap molasses fermentation not air bubbling
ozgar
Post by ozgar »
Hi, on monday 15-02-10 at 9:51 i started to ferment my wash out of molasses, I used 3 parts of water per one of molasses, i reached 30 Brix, i used Liquor Quick Turbo Yeast X-Press w/agents, i used like 80 gms of it. i mixed them all, then i closed it with a homemade airlock, which is a plastic tube that goes to water bottle, filled with water. I think something is going wrong because i haven´t seen any air bubbles on it, but i see that it has all those bubbles in top of the wash, and i see that is fermenting, because i looked at it and i saw that it was like making little bubbles inside the wash
Tater
Re: Blackstrap molasses fermentation not air bubbling
Post by Tater »
Thats kinda heavy on the brix Id add water to drop to 25 or so . You probably got a leak in your blubber somewhere
ozgar wrote:i mixed them all, then i closed it with a homemade airlock,
Assuming that "it" is a plastic bucket, you might have a leaky lid seal... You could try sealing the lid to the bucket using duct/duck tape...
ozgar
Post by ozgar »
tater wrote:Thats kinda heavy on the brix Id add water to drop to 25 or so . You probably got a leak in your blubber somewhere
hi, what can i do, because it is very well sealed with duct tape and plactic bag, note: i used a plastic carboy, and what can i do to get those 25 Brix, because if i open it, oxygen will come in. what should i do ??? HELP ME!!!!!
also how long it takes to ferment everything??? i also heard that blackstrap molasses do not ferment very well :S
HELP MEEEE!!!!
Tater
Post by Tater »
Airs not gonna hurt it.Ya should of stirred some in wash
ozgar
Post by ozgar »
thank you i just added watter, and i proved it and it doesn´t taste like alcohol, how much time does it take to ferment??
Tater
Post by Tater »
depending on several factors can take long as a month . you used turbo yeast so that should of had added nutrients. if temp is kept 75 0r so should do fairly quick say week or so. When it quits bubbling its should be done.Be a good time to start reading and doing searches on questions ya have.
still crazy
Post by still crazy »
How deep into your bottle of water is your tube?
You only need about 1/2" in case of evaporation 6" or more is quite a bit of bubbles to push the water out of the tube may take a while.
Just a thought.
ozgar
Post by ozgar »
still crazy wrote:How deep into your bottle of water is your tube?
Just a thought.
i think that might be the problem, the tube is long, it goes from the top of the carboy, to almost the bottom of it, because i grabbes the bottle with the carboy with duct tape.
Thank you guys :)
