110v SS Copper Micro Heat Exchangers - Ebay
All,
Here is a link to a small heat exchanger which I'm going to try out on a still. Dimensions are roughly 6"x12"x3" with 3/8" tubing. 110 volt dual fans for airflow. They retail for over $300.00.
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... fresh=true" onclick="window.open(this.href);return false;" rel="nofollow
- Attachments
- heat-Exchanger-Lytron-4121G3-s.jpg (10.7 KiB) Viewed 1702 times
Re: 110v SS Copper Micro Heat Exchangers - Ebay
Your not going to try to use that for your liquor output condenser are you?
negative ghostrider. I'm experimenting with ways to reduce waste water and maintain coil temperatures.
That's what I thought cool, I think it's a great idea. What about this, rather then wasting that heat could you find a way to recycle it? Maybe find a way to preheat the next run on a big day where your going to do 3 or 4 striping runs?
Yeah, that is a great idea.
That's a nice heat exchanger. I wouldn't pay $300+ for it but that's a nice price on ebay. I'm thinking I could build one for less than $75 and that's not shopping around.
Rubber Duck Are you thinking something like running your cooling water through a coil submerged in your next wash then returning back to your coolant reservoir? It would heat up your next wash and cool the coolant return at the same time. I kinda like that idea.
Wasnt there a guy that pitched this idea not to long ago. I think it was dunder that said the wash would start evaporating/losing alcohol long before it started to boil.... If i remember right.rubber duck wrote:That's what I thought cool, I think it's a great idea. What about this, rather then wasting that heat could you find a way to recycle it? Maybe find a way to preheat the next run on a big day where your going to do 3 or 4 striping runs?
-Control Freak-
AKA MulekickerHDbrownNose
Rubber Duck's definitely got the right idea. I think that's what the Revenoor continuous systems are designed to do. When I look at the pictures I could speculate that design is it.
Actually if you configure it right a pre heating system will work, but yes you need to be careful to not over heat it. If you push the rig to hard it can be a problem depending on how it's set up.
If you did wouldn't it be minimal? Not even enough to worry about I would think.MuleKicker wrote:Wasnt there a guy that pitched this idea not to long ago. I think it was dunder that said the wash would start evaporating/losing alcohol long before it started to boil.... If i remember right.
the one listed on ebay is built for cooling laser producing medical equipment. My impression is that its pretty highly engineered.
Seller was a fraud. Had to claim a refund from ebay
In theory, losses of alcohols from a preheater system would be primarily fores and less desirable heads...
just thinking out loud...
this is the internet
Wow...!!! That really dragged out, didn't it... Sorry to hear about your dilemma...Horse_Shoe wrote:Seller was a fraud. Had to claim a refund from ebay
