new 2" cm family member
Hey all, built a little.cm to play with, don't have any experience with coil type condensers so.thought it was about time to step up.and learn. 800mm column, 250mm pc. Coil/coldfinger for each condenser. Just did first sac run, surprised at how.well the coils work!. Very responsive and knocks down well!. The coolent lines.are just temporary till I figure out what I want. output was around 72% without packing running pretty quick. Will do a run later with packing and a fresh wash.
"Homer J Simpson"
"Homer J Simpson"
- Tokoroa_Shiner
Re: new 2" cm family member
Oooohhh shiny. Hopefully she puts out good for ya.
The Rules By Which We Live By
Safety And Related Issues
New Distillers Reading Lounge
Thanks.mate.
"Homer J Simpson"
"Homer J Simpson"
Nice... Looking forward to hearing about performance results...
Pretty copper! Do you have a picture of your coil/cold fingers?
Thanks.rad, didn't get to do a packed run tonight, tomorrow. I didn't get pics justsaying.
"Homer J Simpson"
"Homer J Simpson"
The 2" all the way through looks very clean. I like it.
- T-Pee
72% and no packing? That's gonna SING!
tp
tp
Handy Links:
The Rules We Live By
GA Flatwoods sez
Handy Links:
GA Flatwoods sez
Thanks pp, yeah was gunna do a liebig with union blah blah blah but thought nah im sick of seeing them. Hope so tp
"Homer J Simpson"
"Homer J Simpson"
Just did a small run with 9% veg wash, packed with lava, got constant 94% @ 1.3 lph, slow! But happy for the first run!. Need to upgrade the PC condenser, had some.vapor now.and then.
"Homer J Simpson"
"Homer J Simpson"
That shiny piece reminds me of my build working with Mash Rookie, as an artist he would not let me settle for function alone I would shine it up and he would say you haven't spent enough time on the buffer. I have to admit my still when first finished was a beauty as is yours. Fine detail work shows me that you are committed to excellence which probably shows through on your product as well.
Tanks bushman, the camera lies! Lol. I do like shinny stuff though
"Homer J Simpson"
"Homer J Simpson"
- jedneck
I think this is gonna be my next build when I get the materials. Good work googe
big help
Dunder
big help
Dunder
Cool Jedneck!, was pretty cheap, only cost about $50-60 for materials.
"Homer J Simpson"
"Homer J Simpson"
G'day Googe, can you tell me where you are getting your Lava rock from in OZ and what the commercial name for it is?googe wrote:... packed with lava...
EDIT: Do you know if this stuff is suitable for the still..
http://www.bunnings.com.au/dalson-3kg-v ... k_p3173371" onclick="window.open(this.href);return false;" rel="nofollow
Hi apr, I've used that bunnings stuff, it's ok but not very porous!. I get mine from the local landscape supply joint, usually called scoria. Comes in 5kg bags of different sizes. I use the 25mm ones, there really porous. The black ones seem best compared to the red.
"Homer J Simpson"
"Homer J Simpson"
Thanks Googe, I wasn't sure whether the product from Bunnings was suitable for the still or not. I will have to check out my local landscape supply places now and see what they carry.googe wrote:Hi apr, I've used that bunnings stuff, it's ok but not very porous!. I get mine from the local landscape supply joint, usually called scoria. Comes in 5kg bags of different sizes. I use the 25mm ones, there really porous. The black ones seem best compared to the red.
No worries mate, good.luck
"Homer J Simpson"
"Homer J Simpson"
- SoMo
Googe how much pipe did you use in height above you RC?
Somo, if i'm understanding you right, I didn't use any pipe above the rc, the coil inlet/outlet pipes are soldered into the column and 90 degree bend joint, just cut some slots in both joints and the pipe sits in there. The rc hangs down in the column from there. Make sense?, is that what you were asking?.
"Homer J Simpson"
"Homer J Simpson"
- SoMo
Yeah Googe sort of it looks like it's maybe 4" to the highest point in the 90* above the inlet outlet. I'm working on a little something and was curious of how much vertical height one can have over the RC.
I've read this ten times and just realized what you were saying. Hard headed I am some times.
- SoMo
Back to the work bench I go, this stuffs addicting man. I was warned.
Sure is addictive mate lol.
"Homer J Simpson"
"Homer J Simpson"
